NI Package Manager (NIPM)
Linux NI device drivers
Hi everyone,
I tried to install 2020 Ni Linux drivers on this page : https://www.ni.com/fr-fr/support/downloads/drivers/download.ni-linux-device-drivers.html#350003
I have a distribution based on Ubuntu 20.04 LTS.
I installed the ni-software-2020-bionic_20.1.0.49152-0+f0_all.deb package and launch the
"sudo apt update" command. I got the following error :
Err :7 https://download.ni.com/ni-linux-desktop/2020.07/deb/ni/bionic bionic Release
Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP : 104.16.190.245 443]
Do you have problems with your certificates ?
Antoine
(5,203 Views)
Accepted by toitoinou
Hi Antoine,
There was a small issue with the certificate, but it should be fixed now. Could you try running apt update again?
Thank you for making us aware of the issue!
Chris
Chris T.
(5,150 Views)
Thank you Chris,
Everything seems to work now.
Antoine
(5,131 Views)
I also had this issue which has been resolved now.
I've installed the nidaq-mx on a Ubuntu 18.04, using instruction below here:
https://www.ni.com/en-us/support/documentation/supplemental/18/downloading-and-installing-ni-driver-...
However, when I plug in my device it is not being recognized.
Is there any solution to this?
I'm working with USB-4432 for microphone data acquisition.
Best,
Meron
(5,070 Views)
I'm having trouble getting my LabVIEW 2020 install to recognize the DAQmx install.  I've installed on openSUSE 15.1, using the Linux instructions:
But I'm also curious how you use the ubuntu version of these drivers... if ubuntu is not supported yet in LabVIEW.  I'm dual booting ubuntu/openSUSE for this express reason.
Greg
Greg R.
(4,611 Views)
