11-09-2022 10:51 AM
I am having problems connecting to the Package Manager, when I try to open the "Browse Products" site I get the attached screen.
Somehow there isn't any communication to the Feed Locator API but I don't know how to get that working?
I have tried uninstalling NI Package Manager and all the NI Software and reinstalled it, but it just keeps saying the same problem.
I hope someone can help me with a solution as I need it working ASAP 🙂
Solved! Go to Solution.
11-09-2022 12:58 PM
Are you behind a restrictive corporate firewall?
Are you using any extra security software?
Is the package manager allowed to access the internet?
11-09-2022 01:52 PM - edited 11-09-2022 01:54 PM
Hi, thanks for the suggestions
No i am not behind a restrictive corporate firewall så I don't think that is the case.
I have now tried uninstalling my Extra Security Software however i still doesn't work.
As far as i can see, the Package Manager is allowed to access the internet through the firewall? 😕
As an other information I can mention that my Package Manager has worked perfectly before, but now all of a sudden doesn't anymore
11-09-2022 01:59 PM
I have tried uinstalling my extra security software, however this didn't help.
Furthermore have I tried to see if the NIPM has access to the internet and as far as I can see, it has acces.
No I am not under any strict corporate firewall.
As a bonus info I can tell that the Package Manager has worked fine before.
11-10-2022 11:43 AM - edited 11-10-2022 11:44 AM
It's possible that there was an outage or maintenance during that time - please try it again today.
Worst case, you can download the offline version of the installer from ni.com/downloads, which doesn't require internet connectivity.
11-11-2022 12:51 AM
I have tried over the last couple of days and it is still not working, however for my supervisor and fellow students it works for them.
Thanks for the reply 😄
11-15-2022 03:43 PM
andr8830,
1) Can you see if you can access this URL in a browser which is how NIPM obtains the connection point to our store:
11-16-2022 02:10 AM
Hi Scott_Richardson,
When I try accessing the 1) link I get the following message:
Hereafter I tried accessing all the three the links in 2 a) which all gives me the message " "code": 403, "message": "A valid API key is required to perform this operation " and when I try 2 b) I get the message "Acces Denied, error code 1020".
Do you know how I should interpret this?
Andr8830
11-16-2022 03:50 PM
Andr8830, those results are what I would expect so there does not seem to be a simple block to what NIPM is trying to access. Will need to get back to you on possible more debugging.
11-17-2022 04:05 AM
Hi Scott Richardson
I hope you can find some other solution 🙂
Andr8830
