NI Package Manager (NIPM)
Problem regarding communication to the Feed Locator API
I am having problems connecting to the Package Manager, when I try to open the "Browse Products" site I get the attached screen.
Somehow there isn't any communication to the Feed Locator API but I don't know how to get that working?
I have tried uninstalling NI Package Manager and all the NI Software and reinstalled it, but it just keeps saying the same problem.
I hope someone can help me with a solution as I need it working ASAP 🙂
Message 1 of 14
(5,774 Views)
Are you behind a restrictive corporate firewall?
Are you using any extra security software?
Is the package manager allowed to access the internet?
Message 2 of 14
(5,747 Views)
Hi, thanks for the suggestions
No i am not behind a restrictive corporate firewall så I don't think that is the case.
I have now tried uninstalling my Extra Security Software however i still doesn't work.
As far as i can see, the Package Manager is allowed to access the internet through the firewall? 😕
As an other information I can mention that my Package Manager has worked perfectly before, but now all of a sudden doesn't anymore
Message 3 of 14
(5,702 Views)
I have tried uinstalling my extra security software, however this didn't help.
Furthermore have I tried to see if the NIPM has access to the internet and as far as I can see, it has acces.
No I am not under any strict corporate firewall.
As a bonus info I can tell that the Package Manager has worked fine before.
Message 4 of 14
(5,722 Views)
It's possible that there was an outage or maintenance during that time - please try it again today.
Worst case, you can download the offline version of the installer from ni.com/downloads, which doesn't require internet connectivity.
Message 5 of 14
(5,684 Views)
I have tried over the last couple of days and it is still not working, however for my supervisor and fellow students it works for them.
Thanks for the reply 😄
Message 6 of 14
(5,662 Views)
andr8830,
1) Can you see if you can access this URL in a browser which is how NIPM obtains the connection point to our store:
2) If successful, the returned json text would have the following embedded URLs which you can also try in a browser. Please confirm that you get the following failures and if not, what do you get?
a) Failure: A valid API key is required to perform this operation
Scott Richardson
https://testeract.com
Message 7 of 14
(5,634 Views)
Hi Scott_Richardson,
When I try accessing the 1) link I get the following message:
Hereafter I tried accessing all the three the links in 2 a) which all gives me the message " "code": 403, "message": "A valid API key is required to perform this operation " and when I try 2 b) I get the message "Acces Denied, error code 1020".
Do you know how I should interpret this?
Andr8830
Message 8 of 14
(5,617 Views)
Andr8830, those results are what I would expect so there does not seem to be a simple block to what NIPM is trying to access. Will need to get back to you on possible more debugging.
Scott Richardson
Message 9 of 14
(5,591 Views)
Hi Scott Richardson
I hope you can find some other solution 🙂
Andr8830
Message 10 of 14
(5,577 Views)
