Error results in UUT Test Pass
Hello Oli and thanks for your response.
- re-run the test --> The result is changed to Pass, no problem.
- ignore the fail --> Yes that is correct.
- terminate --> if terminated it records a TEST_WARN as per the cleanup in MainSequence.
If Error I would expect to the overall result to be a TEST_FAIL, however it is recoding a TEST_PASS. What do I need to do to make this record a pass?
LABOR OMNIA VINCIT
Message 11 of 22
(194 Views)
My last response was incorrect, and you cannot edit post by looks of things.
If Error I would expect to the overall result to be a TEST_FAIL, however it is recoding a TEST_PASS. What do I need to do to make this record a FAIL?
LABOR OMNIA VINCIT
Message 12 of 22
(185 Views)
In TestStand, a RunTime Error doesn't neccessarily mean, that the DUT has failed (in dubio pro reo).
So when you perform checking in the Cleanup section, you also need to consider
RunState.SequenceError
Message 13 of 22
(166 Views)
Thank you again for your help... loving the Latin by the way 😄
When our CM tests product and get and error like this, as they are running TestStand in "Operator" mode they only get the options to Run Cleanup or Abort Immediately, and this is where my cleanup is recording the TEST_PASS.
Thinking about it this shouldn't be a fail as it could be instrument error, comms error, etc, so in the cleanup I would like to add this error state so it gives a TEST_WARN.
Do I need to add in an extra "Else if" statement, or for the existing one can I have
Locals.termState!=1 || RunState.SequenceError.Occurred
LABOR OMNIA VINCIT
Message 14 of 22
(154 Views)
I don’t see a reason why
shouldn’t be sufficient
BTW…. You are really letting operators use abort? This leaves the system in some state. IMHO it should only be used by a technician who understands the issue and will be able to get the system going / recover to be operational again
Message 15 of 22
(146 Views)
I did not know you could change this, how would you remove that option for operators?
LABOR OMNIA VINCIT
Message 16 of 22
(137 Views)
Struggling to get this working, have tried the following.
Locals.termState!=1 || RunState.Step.Result.Error.Occurred!=False
Locals.termState!=1 || RunState.Step.Result.Error.Occurred==True
AnyOf(Locals.termState!=1, RunState.Step.Result.Error.Occurred==True)
 Also tried the above with "Step.Result.Error.Occurred"
Cannot seem to get it working.
LABOR OMNIA VINCIT
Message 17 of 22
(131 Views)
Sorry, almost (but only almost) forgot about this thread 😉
More info asap
Message 18 of 22
(110 Views)
Sorry for the delay....
I tried to think this through, but I'm a bit stuck... which (use) case is actually not working?
Message 19 of 22
(96 Views)
Message 20 of 22
(94 Views)
