NI TestStand
How to call test Sequences developed by using CVI Test Execuitve toolkit in Test Stand?
There is a feature in TestSatnd which can convert CVI sequence to test Stand Sequences. But test stand is not recognising these sequences saying " not a valid CVI test sequence". Is there any version Issues, while converting these sequences to TestStand?
(3,337 Views)
To AmitG -
TestStand provides a conversion utility for converting LabWindows/CVI Test Executive Toolkit 2.0.x sequence files to TestStand sequence files. If the version number of your LabWindows/CVI Test Executive Toolkit is less than 2.0.x, you must first load and resave the sequence file in the sequence editor for LabWindows/CVI Test Executive Toolkit 2.0.x.
Scott Richardson (NI)
Scott Richardson
https://testeract.com
(3,337 Views)
Hi Scott
In continuation of previous question..
As per the suggestion, when I am trying opening one sequence(.SQU) file,developed in CVI Test Executive V 1.0.1., in CVI Test Execcuitve V 2.0.1, Executive is throwing error.
The Pop Error is " Section [Sequence] missing from sequence file c:\xxx.squ"..
and when I am trying opening these sequence file in sequence editor, the tool it self is crashing.
Please suggest!!
Is there any specific tokens which we need to add in .SQU files of V 1.0.1, so that V 2.0.1 can understand them? Just to check the possibility of manual updation of .SQU files.
Regards
Amit
(3,337 Views)
Amit -
My only suggestion is to post the CVI Test Executive V 1.0.1 sequence to this thread and I can take a look at it.
Scott Richardson
(3,337 Views)
