NI TestStand
Return long variable of .net Adapter
I try to return a long value from a method in a .net Adapter and try to give it a TestStand Number variable. I get the following error message in the step Settings: "Expected Number {Signed 64-bit Integer}, found Number {64-bit Floating point}"
Can you help me?
Best Regards!
(531 Views)
Accepted by tlkr01
You might wanna try to change the variable properties
(520 Views)
Thanks for your help. Your suggestion solved my problem!
(515 Views)
