Switch from 32 bit to 64 bit and test stand no longer runs
@thosquanta wrote:
i believe it has been minorly altered by my predecessor, but it looks pretty close to the default to my eyes.
Any Minor issue can create issue, to verify you can verify with the default User Interface/TestStand to validate your sequence.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 11 of 12
(434 Views)
Accepted by thosquanta
I did some more poking around. It seems like my issue was the process model switched to default on the 64-Bit version of TS. Once updated, it works just fine.
thanks for the insight!
adam
Message 12 of 12
(428 Views)
