NI TestStand
TestStand 2014 Cleanup after failed a step
Hi all,
I'm new to TestStand, so I have simple question which might boring you but I cannt find the solution.
In my Main Sequence I have say 50 steps. If one step failed the next step will be executete (by deafult).
What can I do to stop the execution of the following steps if one step failed. I wish that the sequencer goes to Cleanup directly insteed call the next step in the Main Sequence.
Any simple hint is appreciated.
Axel
LabVIEW 2014 SP1 f3, LabVIEW FPGA 14.0.1
TestStand 2014, Windows7 Enterprise 64-bit
(4,086 Views)
Accepted by Axel56
You can set the sequence to goto cleanup on sequence failure by setting:
Configure >> Station Options >> Immediately Goto Cleanup on Sequence Failure
Also check that the steps will cause a sequence failure on a step failure, by configuring:
Step Settings >> Step Failure Causes Sequence Failure
I hope this helps,
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(4,082 Views)
