Teststand and ECU MC Toolkit
I use Labview 2012, Teststand 2012, XNET 15.5, DAQmx 15.5.1, ECUMC 15.0 with cDAQ-9171+NI-9862.
This is the setup on my desk PC to write test software for a automotive product.
In the test field is used "Teststand debug deployment environment 2012". I have to install XNET 15.5, DAQmx 15.5.1, ECUMC 15.0 with cDAQ-9171+NI-9862 on the test field PC and I'm not sure if this setup is compatible to my setup.
Are there any differences I have to take into account?
HH
(2,577 Views)
Accepted by HH_2018
I'm not completely sure what you need to know exactly, but my 50 cent:
To write test software (= TestStand sequences) you will have to use the TestStand Development License
If you want to deploy sequences to a system in the field, and run them,
- you have to create a operator interface as EXE or use one of the examples provided with your installation. Probably you will do that already, as operators are not very happy with the sequence editor
- you are not allowed to use the sequence editor for operator actions, but solely for debugging purposes. You agreed to that when you bought the Debug Deployment License
- you copy the sequences to the target
- you copy the driver & sw setup to the target, i.e. using the TestStand Deployment Utility (https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/installer-options-tab-testst...)
For your field system you will need to install the LabVIEW Run-Time Engine, you forgot that in the list 🙂
Besides that at least I see no obvious issues. Are there any specific issues you worry about?
(2,488 Views)
