NI TestStand
Unable to load LabVIEW VI into TestStand using LV Run Time only
Hi Eric, To resolve this issue go to Configure->Adapters and select Labview adapter and click on Configure. After that a new window will open and in that select the Labview Developement System and click ok. This should resolve your problem
Message 31 of 31
(640 Views)
