06-15-2023 11:41 AM - edited 06-15-2023 11:42 AM
Hello Folks,
I am required to update only subsequence results (Testcase as subsequence) to the MySQL Database. I'm able to connect and configure the database in TestStand using the result processing option. I have the following table in my Database, data is to be updated as per this.
Can you help me with this requirement, Here I would like to use the result processing option instead of using the Database Step type in the TestStand sequence.
| Date and Time | Version | Test Case 1 | Test Case 2 | Test Case 3 | Test Case 4 | Test Case 5 | Test Case 6 | Test Case 7 | Test Case 8 |
| 06/15/2023 8:00AM | 1.0.0 | Pass | Pass | Pass | Fail | Fail | Fail | Fail | Fail |
| 06/16/2023 8:00AM | 1.0.1 | Pass | Pass | Pass | Pass | Fail | Fail | Fail | Fail |
| 06/17/2023 8:00AM | 1.0.2 | Pass | Pass | Pass | Pass | Pass | Fail | Fail | Fail |
| 06/18/2023 8:00AM | 1.0.3 | Pass | Pass | Pass | Pass | Pass | Pass | Fail | Fail |
| 06/19/2023 8:00AM | 1.0.4 | Pass | Pass | Pass | Pass | Pass | Pass | Pass | Fail |
| 06/20/2023 8:00AM | 1.0.5 | Pass | Pass | Pass | Pass | Pass | Pass | Pass | Pass |
Thanks in advance
Vipin
09-11-2023 03:03 AM
If you go to the properties of each step there is a option of results logging.
You can enable the logging only for the required steps.Disable others.
Then only the desired steps will be logged ( be it in report or database).
Ravi
09-11-2023 03:50 AM
Thanks for the reply.
I need other information in the ATML Report. So, I won't be able to disable the result recording options in each steps.
-Vipin
09-11-2023 04:19 AM
Hi Vipin,
I dont think you cannot selectively log for DB and different for the report.
1) For the DB you can use the DB step types and update the required data to the database. Refer DB examples.
2) Let the DB log everything.Write a SQL query to fetch only what is required.
3) Collect all dat a and send to a VI to log to database.
Ravi
09-14-2023 11:17 AM
I'm using the second option. I just want to know, if is it possible to use a customized Database model Plugin.
