how to creat a summary of report with .txt
Hi All,
     I want to creat a summary of report with .txt,and i have disabled the function about report generation in teststand.
     i created a complex sequence,it include some sub-sequences,example:the uut is tested on three different temperatures and four different voltages conditon.So i have creat three sub-sequences (diffrent temperatures) include four steps (different voltages),then mainsequence invoke three sub-sequences to excute test.
    i only want get the fail-step's summary with,include: fail-step's name,status
    how to do?thanks a lot
(3,409 Views)
Take a look at the FailureHandlerExample.seq in the TestStand\Examples\Callbacks\PostStepFailureCallback folder. You can add failed step information to a text file inside of SequenceFilePostStepFailure callback.
CTA, CLA, MTFBWY
(3,394 Views)
Hi snowpunter,
    Thanks for your reply.i tried it with SequenceFilePostStepFailure callback.and when the step failed,i can get the step's name with NameOf(RunState.Caller.RunState.Sequence).
     But i want more informations inclue up-level sequence.Because i have used some "sequencecall".So user can easy to know what conditon
bring out the failure.
    How to do that?
BR
John
(3,388 Views)
Accepted by cat099
You can use Parameters.Step.Name to get the failed step name. You can also use something like Parameters.Step.StepType.Name == "NI_MultipleNumericLimitTest" to filter different types of steps.
As far as finding the entire failure chain...
You can check RunState.CallStackDepth to see how many callers deep you are. Based on that information you can use RunState.Caller.Caller.(continued for however many callers deep you are).RunState.Step.Name or .Sequence.Name
So if the CallStackDepth is 1, you would only need to use one Caller. If it was 2, you would need to recursively use 1 Caller and then 2 Callers and so on.
CTA, CLA, MTFBWY
(3,376 Views)
thank you.it is done
(3,359 Views)
