NI TestStand
obtaining the step limits out of a sequence from a labview program
I am writing a labview program to access teststand sequences' various properties to automatically grab the data out of the sequnce for documentation.
The step.limits.high property is very difficult to retrieve from the teststand sequence programmatically using just the sequence file as the input.
Does anybody know how to obtain the limits on a step from a sequence file?
Message 1 of 9
(6,329 Views)
Not all steps have that property.  Are you seeing it error out?
You could do one of 2 things:
1- Check if the property exists first and then get it.  use the Exists method of the Property Object class.
2- Check which StepType you are dealing with and then only get that property when it is a NumericLimitType.  Step.StepType.Name will return the step type.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 9
(6,316 Views)
Thanks Sir but I am still having problems.  When I created a dummy sequence which has only a numeric limit test in it with limits and units populated in the step, I always get the "Exists" method returning a false.
I suspect that it may be my lookup string (Step.Limits.High).  Any help on that may be my next benefit from you.  See attached.
Message 3 of 9
(6,300 Views)
Only use the StepType stuff if you are trying to look at different step types.  If you only care about the Numeric then look at what I've done below.
Hope this helps,
jigg
CTA, CLA
testeract.com
Message 4 of 9
(6,293 Views)
That works !
Now one more question - how do I get the Step.Description field...I do not see anything that looks like that lookup string.  "Step.Description" does not work...
Message 5 of 9
(6,285 Views)
Check out attachment.
jigg
CTA, CLA
testeract.com
Message 6 of 9
(6,282 Views)
Thank You overy much....they both worked.
Now I am stuck again with the Step.Limits.Units...any help is appreciated and I promise I will close this after this one..this stuff isnt very intuitive
Message 7 of 9
(6,272 Views)
I got busy.  Just saw this.
Units is stored in the Results container so you need to do Results.Units.
Attached is a screenshot of how you can find the lookup strings.
jigg
CTA, CLA
testeract.com
Message 8 of 9
(6,242 Views)
Accepted by id
Thanks alot sir.  I will take it from here.
Message 9 of 9
(6,229 Views)
