PXI
Error initializing a PXI 6602
In a PC runnig RedHat Linux I have a PXI 6602 inserted in a PCI slot using a PCI-PXI adapter. Lspci reports the following message for this board: "!!! Unknown header type 7f". Does somebody know if this means that the board is defect ?
(3,606 Views)
What kind of PCI-PXI adapter are you using?
Is there any way you can try this in an actual PXI slot? Try another machine with the same adapter?
What specific distribution of RedHad are you using?
Peter Flores
Applications Engineer
(3,596 Views)
- I'm using a CompactPCI to PCI bus  32-bit adapter, made by LeCroy
- RedHat Enterprise Linux 5.2
- I have no access to a PXI slot
(3,591 Views)
I tested the PXI 6602 board on a second computer and it worked.
I am sorry; please disregard the initial request. It may be OS or platform related.
Thank you!
(3,585 Views)
