11-26-2008 08:06 AM
I have some millimar sensors and I would like to work with the data directly on my computer. For that I would like to use PXI and a appropriat card.
Do you see a good solution with NI components? Other companies are supplying cards for that already.
11-27-2008 06:48 AM
You can read all sensors with our cards but you must be with your signal in our specifications of each card you use e.g. 0 to 10 mV or 0 to 20 mA. So often you need an amplifier or an transducer to form your signal in voltage or ampere with right range.
What signal and unit do you get from your sensor ? Do you have a datasheet ?
Best Regards
03-06-2009 02:15 PM
03-11-2009 08:14 AM
We have additionally Signal Conditioning and special Voltage Ranges from +/- 80 mV to +/-10 V with 24 bit resolution -> 9.5 nanoVoltage Resolution possible.
So we can use almost all sensors with Labview. So please describe your specially specification for what card you need ?
For Labview drivers you can use dll´s with C programming with external function node when not finding Labview Vi´s.
Best Regards
