01-15-2019 05:08 AM - edited 01-15-2019 05:13 AM
Good day,
my PXIe-1071 power led as turned steady red and the pxi does not start. I discovered that for other devices this code means that the main fan is broken, could this be the same case?
Thank you very much,
Francesco
Solved! Go to Solution.
01-16-2019
02:07 AM
- last edited on
09-22-2025
03:17 PM
by
Content Cleaner
Hi Francesco,
according to the NI PXIe-1071 User Manual,
The chassis power inhibit switch has an integrated LED.
If the inhibit switch LED is red, the system fan has failed, and the chassis has shut down to protect modules from damage due to insufficient cooling.
Does it answer your question?
Alessia
01-16-2019 02:48 AM
Yes. Thank you very much.
Francesco
