PXI
PXIe-1071Power Led steady red
Good day,
my PXIe-1071 power led as turned steady red and the pxi does not start. I discovered that for other devices this code means that the main fan is broken, could this be the same case?
Thank you very much,
Francesco
(2,837 Views)
Accepted by FM82
Hi Francesco,
according to the NI PXIe-1071 User Manual,
The chassis power inhibit switch has an integrated LED.
If the inhibit switch LED is red, the system fan has failed, and the chassis has shut down to protect modules from damage due to insufficient cooling.
Does it answer your question?
Alessia
(2,815 Views)
Yes. Thank you very much.
Francesco
(2,809 Views)
