PXI
Unable to install the base system images on NI Linux RT
I'm installing the NI Linux RT environment on a PXIe-8821. However, when I tried to install the base system images, I found myself unable to get any options available. PXIe-8821 is now in safe mode. Does anyone know the solution to this issue?
(345 Views)
Have you installed NI Linux RT System Image on your host PC?
https://tmesystems.net/
(324 Views)
Thank you for your reply.
Yes, I've installed it.
(307 Views)
Accepted by john_doe_2025
I solved it by downgrading the firmware to version 21.1.xxxx.
(300 Views)
