QControl Enthusiasts
Don't find QControl template (tool?)in new vi dialog.
Hi Quentin
I have installed your toolkit without error, but when I try to create one QControl, I don't find the template in the New VI dialog.
I have LV2018 SP1 in the french edition.
Any suggestion to solve this?
(3,375 Views)
Accepted by topic author TheQ
I submitted this as an issue to the QControls Toolkit on GitLab.  It is caused by how "QControl" gets added to the New Dialog.  The addition of QControls to the New Dialog looks for the item "Other Files" to place "QControl" as a child in the tree. This fails in non-English versions of LabVIEW where "Other Files" is in the language of the LabVIEW version. "QControl" needs to get added regardless of the language version of LabVIEW.
As a workaround until a fix is in place, you can go to [LabVIEW 20xx]\resource\plugins\QControl\New QControl.vi.
This will run the QControl Creation Wizard.
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
(3,337 Views)
Accepted by Eric_BOB
Thanks, TheQ for your quick reply.
I will use your workaround until you solve this.
If you need a tester for the new release install in french versions, I can do it for you.
(3,321 Views)
