Quick Drop Enthusiasts
Is it possible to create a QD for "disconnect from typedef" ?
George Zou
Message 1 of 14
(10,863 Views)
How ?
George Zou
Message 3 of 14
(6,080 Views)
I think it would be quite simple.  The Control object type has an invoke method of "Disconnect from Typedef".  Calling that on the selected object(s) should do the trick.  I'd recommend looking at how some other quick drop functions have been made found here to get an idea of how to make it.
https://decibel.ni.com/content/groups/quick-drop-enthusiasts?view=documents
Message 4 of 14
(6,080 Views)
There is already a JKI Right Click Frame Work VI that does this.
(Disconnect from Typedef Recursive)
Just copy that code into a QD function.
Message 5 of 14
(6,080 Views)
Is JKI Right Click Frame Work free ?
George Zou
Message 6 of 14
(6,080 Views)
The right click framework was developed by JKI before QuickDrop existed to help speed development in a similar way. It is free and google search should bring it up. But it is no longer being since QuickDrop.
Message 7 of 14
(6,080 Views)
RCF is available via VIPM.  But we found that it doesn't work with newer versions of LabVIEW.  I want to say it was with 2011 that RCF got broken.  And JKI is no longer supporting it.  So I don't recommend going that route.
GCentral
Message 8 of 14
(6,080 Views)
I took a stab at writing this shortcut. You can get it here:
https://decibel.ni.com/content/docs/DOC-37041
LabVIEW 2013 and later.
Message 9 of 14
(6,080 Views)
I also got mine to work.
I use this function:
It disconnects all typedefs on the front.
George Zou
Message 10 of 14
(6,080 Views)
