Quick Drop Enthusiasts
Quick drop cause LabVIEW crash
Don't why Quick drop start to cause LabVIEW crash.  All version of LabVIEW crashes.
It's ok to drop a ctrl on the FP, or drop a node on the BD.  But when I use any plugin, even ctrl-R, LabVIEW crash every time.
Anyone run into this before?
I spent a few hours to run a repair, and it does fix the problem last Friday,  but only to find out the problem comes back today.
Windows 10 Pro, LabVIEW 2014-2020
George Zou
Message 1 of 9
(7,342 Views)
Accepted by zou
Hello George.
Do you have any 3rd party Quick Drop plugins installed?
does the error persist if you remove all 3rd party plugins?
BR
Jesper
GCentral
CTD + CLD + Pythonista
Message 2 of 9
(7,333 Views)
Accepted by zou
Have you already removed any custom QD plugin VIs you might have added? Seems like a broken plugin could cause this.
Message 3 of 9
(7,332 Views)
Thanks for quick response.
But this can't explain the repair works.
After repair, I haven't add any 3rd party plugin yet.
It's painful without QD.  I'm so used to QD, it's hard to avoid it.
George Zou
Message 4 of 9
(7,318 Views)
Could you provide the following:
LabVIEW Version that this occurs in.
List of quickdrop plugins you have installed?
- Customized plugin short-cuts?
Best regards
Jesper
GCentral
Message 5 of 9
(7,308 Views)
After the repair, remove your LabVIEW.ini file and your LabVIEW Data folder (make backups of course), and then see if things work. That would be the 100% default, no add-ons install of LabVIEW.
Message 6 of 9
(7,302 Views)
@Jesper
All versions of LabVIEW installed crashed before repair; now only the one I'm using: 2017.
I have a lot of QD plugins, some I made myself.
George Zou
Message 7 of 9
(7,291 Views)
It looks like the QD triggers the crash, but the root cause maybe something else.
I was doing VISA Read/Write to a 3rd party instrument, and getting errors.  After I fixed all the bugs, no more crash.
That reminds me that I had similar situation before:
https://forums.ni.com/t5/Quick-Drop-Enthusiasts/Is-it-possible-to-create-a-QD-for-quot-disconnect-fr...
Kudos to Jesper, Ian and Darren.  Your response help me eliminate other possible causes.
I'll let you know if the problem comes back.
George Zou
Message 8 of 9
(7,268 Views)
No.  Still crashing.
Removing all 3rd party plugin solve the problem.
Jesper and Ian are right on day one.
It's my own plugins broken.  SubVIs have been upgraded to newer version.
I know they are broken for a long time.  Don't know why they cause problem now.
George Zou
Message 9 of 9
(7,166 Views)
