Can see cRIO modules using offline PC and offline cRIO
I have two NI-cRIO-9053 and am trying to read thermocouple data using LabVIEW 2024Q1, however, am unable to see the cRIO modules in NI MAX. My PC and cRIO are air gapped/offline and cannot be connected to the internet. Also, when I press the add/remove software button on the cRIO in NI MAX it gives me an error. What do I need to do in order to get NI MAX to see and communicate with the cRIO modules?
Things tried
Setup the IP Addresses correctly and can ping both cRIO from the PC.
Both the Ethernet and the USB C connected.
Reinstalled the firmware.
Was trying to use the command line NI package manager to install DAQmx, however keep getting syntax errors pertaining to either the package or the lo
(988 Views)
Accepted by djnbae
You need to install software to your cRIO from the host PC.
For offline host PC: Downloading Individual Offline Installers for NI Software
For offline cRIO: Installing Software to Offline NI Linux Real-Time Targets
https://tmesystems.net/
(965 Views)
I try selecting add/remove software on the cRIO from NI MAX and get the following error.
What software do I need to install?
(955 Views)
The required software are listed in the links I shared. Please read them carefully.
It is NI Linux Real-Time Offline Installation Support
(830 Views)
