RT get CPU loads
I'm using "RT get CPU loads" on a cRIO-9004 and it outputs only NaN and no error.
It worked on a cRIO-9014. Using Labview 9.
(4,697 Views)
Hi Snamprogetti,
unfortunately I get your behaviuor too. I find that this NAN is also provided on Distributed System Manager.
I report this incorrect behaviour to R&D but, for now, there is nothing new that we can do.
I'm sorry.
Cheers,
Matteo Brunella
Application Engineer
NI Italy
(4,683 Views)
Accepted by Snamprogetti
Check out this article here , Try enabling microsecontimingmode=1 and then check whether it is working. There is already a CAR filed on this behavior.Hope it helps
-Mallya
" Appreciate and motivate those who help"
(4,659 Views)
OK, now it works. Also, it is good to know how to sync the system time.
The total CPU usage with controller doing nothing (except for getting CPU loads every second) is now 10%, i hope this is normal
(4,639 Views)
As suggested in the KB, there is always an overhead of synchronizing and enabling the microsecond timer. That is the reason it is not enabled by default.
-Mallya
(4,630 Views)
