Read/Write data From/To FPGA
Hi there,
A simple one:
I have a RT application where I transfer small amounts of data (around 1Kb) between 5 FPGAs (7813R) and a microprocessor (8106RT) at high speed (2KHz). The data is used to implement a closed loop control system, so I really ned new data available in the uP each 500us. Ideally for the stability of my system I would need to do all the reading, processing and otputs writting in less than 100us.
DMA FIFOS don't seem to be a good option for this application and the Read/Write block have proben to be too slow for my requirements (around 100us to read from FPGAs, 70 us to write to FPGAs)
Do I have any other option for doing this data transfer? Is there any way of using lower level code/instructions other than this Read/Write blocks and implement a faster communication
Cheers,
Jose
Message 1 of 1
(3,749 Views)
