cRIO 9076 Unable to Detect Physical Channel
Hi All,
I am currently attempting to acquire data using NI cRIO 9076 Integrated Controller but am unable to create virtual channels using DAQmx. My situation is summarized below.
Hardware :
NI cRIO 9076 Integrated RT Controller
NI 9205 Analog Input Module
NI 9403 Digital I/O Module
Software :
Labview 2011
Compact-Rio 4.0
MAX 5.0
NI DAQmx 9.3
All channels of C-series module and chassis are visible in NI Distributed System Manager and Labview Project Explorer.
Visible
But when using MAX to create a new DAQmx task, I am unable to detect the physical channels. Both NI DAQmx in Labview and right click at Data Neighbourhood in MAX to create NI DAQmx Task/Global Virtual Channel are giving out the message  "No Supported Devices Found".
Plus, the hardware also does not seem to appear under the "Devices and Interfaces-Network Devices".  When comes to "Find Network NI DAQmx Devices" it was stated that "No Devices Were Found". The controller was named "VIGREN". Manually detecting using host name and IP also failed to detect.
My question is:
1. How come the PC detects the chassis and modules but when it come to NI DAQmx, it does not detect the physical channels ? Is this a software/hardware or network related issue?
 2. Are cRIO 9076 RT controller not compatible with NI DAQmx ? And hence Scan Interface or FPGA Interface has to be used instead? Given the its seamless feature, I would prefer to continue use NI DAQmx to configure my data acquisition.
Thank you.
(6,990 Views)
Accepted by Vigren
Hi Vigren,
I think you misunderstand some of the concept here.
cRio is a real time system and is not a DAQ board which you cannot use DAQmx with it.
You can refer to this discussion link for more information
http://forums.ni.com/t5/Multifunction-DAQ/cRIO-9073-compatibility-with-NI-DAQmx/m-p/1194163#M58721
You can use either scan mode or FPGA to do the acquisition.
TuiTui
(6,954 Views)
Thank you TuiTui.
(6,949 Views)
