how do I get the Pretrigger data with the HW analog trigger
I use startcondition type = cwaiHWAnalog but I need to set the pretrigger time. I set CWAI.GetStopCondition().SetPreTriggerScan = 200. When I acquired the data, I do not get the pretrigger data. What was wrong in the setup?
(3,323 Views)
Hello;
You didn't mention what version of NI-DAQ neither what DAQ board are being used on that application.
In case you are using the Lab-PC+ board, there is a known issue with the Pretrigger Trigger event. For more information on that perticular issue, type +lab-pc +pretrigger +componentworks at www.ni.com search field.
Regards
Filipe A.
Applications Engineer
(3,323 Views)
