is NI SBRIO 9642XT power connector J3 negative terminal internally connected to ground lug and plated mounting holes
i have an SBRIO system with an isolated power supply
http://www.ni.com/pdf/manuals/375052c.pdf
on page 15 , it says all ground connections AI, AO, D GND are internally connected to earth ground lug,
is the power connector J3's negative terminal also connected to earth ground internally ?
i have a system assembled on a aluminuim enclosure which has the earth ground connection , and also the power supply that is used to power the sbrio gives out isolated voltage, but now if the J3 power connector's negative terminal has internal connection with the holes and ground lug, how can i use my isolated power supply whose negative terminal is not connected to the earth ground, its main AC power supply has the earth ground connection not the DC output.
i am unable to open the sbrio board from my system at this time to check directly.
can some one please help if the J3 power onnector's negative -ve terminal is internally connected to the ground lug and mounting holes.
(4,630 Views)
any one know the answer?
NI app engineer or some one who has an sbrio and a multimeter, plz help
(4,623 Views)
Accepted by freemason
Hi freemason,
I believe I just sent you an email regarding this, but to confirm, yes, connector J3 is connected to earth ground internally. You should still be able to use your power supply for the sbRIO.
Best,
Dan N
(4,618 Views)
