SystemLink Forum
SL Asset Manager
Hereby the time out error I get when I run the copied notebook under my own user (admin role, LDAP in case it matters).
SL19.0 - Asset Manager - exclamation mark issue - connection history notebook time out error.PNG
André (CLA, CLED)
Message 11 of 16
(1,977 Views)
What are the specs of your server (RAM, SSD?, Cores) or are you running it just on a VM? Its possible your system is running low on RAM, which may cause the notebooks to fail to execute.
Also, are you logging in with admin, LDAP, or Active Directory?  If you are using LDAP or AD are you logging in as a user that has been added to the SL administrator group?  Could be a permissions issue since I think the default permissions only allows administrators to run notebooks, which is what is backing the charts.
Message 12 of 16
(1,945 Views)
Hi Joshua,
I already gave this info to Brandon through email. In addition I can tell you it's not a VM.
Thanks.
André (CLA, CLED)
Message 13 of 16
(1,938 Views)
Hi Joshua,
Any updates regarding this issue?
Thanks.
André (CLA, CLED)
Message 14 of 16
(1,886 Views)
Do you get a similar error if you download one of the Test Monitor jupyter notebooks, upload and run it directly in Jupyter?
The Asset Management Service is clearly running, because the other tiles are showing valid data.  If the reports in the dashboard didn't work, but the Jupyter notebook did, I would say it is a permission error.  If the other tiles didn't have valid data, I would say you have a problem with your asset management service.
However, I'm at a loss on my the Jupyter Python Notebook would fail to access the data when the service is clearly up and running and returning data.
Message 15 of 16
(1,880 Views)
Hi Joshua,
One of my previous posts I show one of the Jupyter notebook I copied and it seems to time out on a particular operation. I ran it inside Jupyter Notebook, otherwise I wouldn't how to find out about the time out.
Maybe I should also ask Brandon what happened with the files I sent him.
André (CLA, CLED)
Message 16 of 16
(1,876 Views)
