USRP Software Radio
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Increasing write rate?
Hi Attique!
I assume this is the same issue you described in a different thread:
http://forums.ni.com/t5/LabVIEW/Urgent-Help-Required/m-p/2186408/highlight/false#M701770
Let's continue there!
Kind regards:
Andrew Valko
Andrew Valko
National Instruments Hungary
Message 11 of 17
(5,351 Views)
Hello Andrew,
Yes this is the same problem discussed in the other thread. We will continue there...
Regards
Attique Ur Rehman
Message 12 of 17
(5,345 Views)
I also try to configure MIMO 2x2 system with 4 USRP 2920. I set IQ rate 200kS/sec but I have error mesages in Tx: niUSRP Write Tx Data (2D CDB).vi<ERR>Packet had timestamp that was late (or too early), and at Rx : niUSRP Fetch Rx Data (2D CDB).vi<ERR>A stream command was issued in the past.. Can you help me to solve this error messages??
In my MIMO 2x2 system, I don't use external clock. I use internal in Clock Source and Frequency Source. Is it wrong?
Hendy
Message 13 of 17
(5,086 Views)
Hello Hendy -
The error you see is related to synchronization. Your command to do a simultaneous start is describing a time that has already past the current time on the inboard clock. This can be caused by setting the time base incorrectly, not resetting all clocks at the beginning of the program, or not connecting an external source when one is selected in software.
Message 14 of 17
(5,078 Views)
Hello Mr Erik
I already implement 2x2 MIMO OFDM using USRP. I want to measure throughput of this system but I don't know how I measure it. Can you help me to solve this problem. Thanks a lot.
Regards
Hendy
Message 15 of 17
(4,203 Views)
šŸ™‚ please read the other forum post... And ask/post there, so we will keep this issue compact
Jozef LiptƔk
Message 16 of 17
(4,129 Views)
I am new to the SDR field. Currently, I am developing a simple USRP Tx & Rx demo. When I increase the IQ Rate to 10M, I am receiving underflow error. What is the maximum IQ Rate we can use?
Thanks in advance!
BR
Shree
Message 17 of 17
(1,743 Views)
