USRP Software Radio
N210_bpsk_modulation
I am a new user of USRP N210 and trying to run the example (PSK TX) from the lab view communication system design suite 2.0 in order to transmit BPSK modulated signal and receive it back just for my research purpose. I keep on getting below attached error. Can someone please help? Is it just the issue of my entered values or any other error?
(3,051 Views)
Hi Ktim,
Do you know what daughterboards you have in your USRP N210?  This is going to determine whether your current channel values are correct.
(2,987 Views)
Hi Luke,
I resolved that problem. I have a new question. I am supposed to produce a BPSK signal covering TV channel 3 (174-180 MHz) and channel 11 (198-204 MHz). I am using daughter board (SBX) in N210 usrp. Can you suggest the type of antenna I can use for my transceiver and receiver?
Ktim
(2,968 Views)
Accepted by Ktim
Hi Ktim,
I looked through all the antennas that Ettus sells and unfortunately, none of them match the frequency ranges you are looking for. I would encourage you to look at 3rd party vendors for antennas in your range. Since we only have expertise in our own products, I cannot make any specific recommendations on what 3rd party antennas to get. You can always reach out to the other antenna vendors for advice in that area.
One thing to watch out for is that the antenna should have a SMA connector so it can interface with your USRP front end.
James F.
(2,947 Views)
