‎07-21-2014 02:47 PM
I'd like to include the Results into a project, or offload the VIA to a nightly process that might not have the same absolute folder structure. Is there a way for VIA accept relative paths?
Solved! Go to Solution.
‎07-21-2014 02:56 PM
I believe the paths stored in both .cfg and .rsl files are relative. So if you save your .cfg/.rsl in a certain location relative to the VIs being tested, and on another system the .cfg/.rsl is in the same relative location to the VIs being tested, it should "just work".
‎09-08-2014 10:25 AM
I'm trying to do the code analysis as a part of a code review from my laptop and send the results file to a coworker (who has the code checked out to a different path). This isn't working. The .RSL file only has absolute paths (as it probably should).
I can make a quick .vi that can fix the paths in the .rsl file and rewrite the .rsl file. However, I need the RSL Exporter to return the Test Config Data cluster as well. Darren, can you add that output to that utility?
Thanks!
‎09-08-2014 10:45 AM
I have updated the RSL Exporter to return the Test Config Data cluster array:
https://decibel.ni.com/content/docs/DOC-26552
Still though, I'm wondering why things aren't working for you. If you save the .rsl file to a certain location, and copy it to another machine where it is in the same relative location to the analyzed VIs as it was on the first machine, it should work.
‎09-08-2014 09:44 PM
The .vi paths may have been a red herring. I get a "reference is invalid error". Could it be that it's not finding the custom test? The Test Path for the custom test looks like :
..\..\..\Users\dan\Documents\LabVIEW Data\VI Analyzer Tests\CTI custom tests\Code Review.llb
So that would be change for a different user.
‎09-09-2014 12:52 PM
Thanks for the info. I think I may have a problem when saving or loading RSL files and not treating paths to custom tests correctly. I have filed myself CAR 492018 to look into the issue in more detail.
‎09-09-2014 04:00 PM
I might have a clue. I made my .vi to adjust the paths of the custom test. If I run the code in LabVIEW it works well. If I build it into an .exe and run it, it fails.
My guess :
The Test Path I put into VIAn Easy Report.vi is an absolute path. (Whereas in RSL Exporter, it comes back as a relative path. Somebody is calculating a relative path!)
When I built my "path adjustment code" into a nice little .exe (so I can associate .rsl files with this utilitly and quickly & easily get them adjusted by double clicking those files). However, I suspect that the .exe build is screwing up the VIA code that is calculating the relative path (it's probably relative to something in the .exe, not in .vi lib or wherever it should be calculating from).
Is the Test Path stored as an absolute or relative path in the .rsl file?
-D
‎09-09-2014 04:12 PM
I just double-checked...the test path stored in the RSL file is always relative to the LabVIEW folder, even for custom tests. My fix for the CAR will be to store a token along with the test path to indicate if it is in the LabVIEW folder or the [LabVIEW Data] folder. I do this for CFG files, it looks like I forgot to do it for RSL files.
‎08-18-2015 05:11 PM
CAR 492018 is fixed in LabVIEW 2015.
