VeriStand
Create a Desktop Real-Time Computer Running Pharlap?
I try to create RT(Pharlap)...follow below steps https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LZiSAM&l=en-US No matter which method I choose...format can't success.. Can help explain the reason??
Message 1 of 10
(4,946 Views)
The screenshot you included is just a warning that when you format the device with a new file system, you will erase any existing data on the drive. Can you clarify what part of the formatting process isn't working?
Message 2 of 10
(4,944 Views)
hi...you can see I typed (y) then reply "Not formatting hard driver."
Message 3 of 10
(4,939 Views)
Ah, I missed that. Is your hardware setup supported according to this list?
Message 4 of 10
(4,929 Views)
I tested my pc that pass all condition....
I can use safe mode to install software by USB boot(select 2)...
And I can usb boot select 1...All functions can work correct...
If I use this method...would be always boot from usb(select 1)..
I think the Pharlap not support SSD HD ???
Message 5 of 10
(4,915 Views)
The SSD should not be a problem. For example, the PXIe 8880 has an SSD hard drive and can be purchased with Phar Lap.
Message 6 of 10
(4,912 Views)
so..Which step might be wrong?
or give me some advice....thx!!
Message 7 of 10
(4,906 Views)
Accepted by hsinhsiang
Hey hsinhsiang,
Have you tried typing "yes" instead of "y"? You may have a BIOS that does not accept "y" as "yes", so the utilities default to not formatting the hard drive. I found some internal documentation that pointed to this as a possible cause.
Message 8 of 10
(4,902 Views)
I make a fool of myself.....
It just types "yes" would be OK..
Message 9 of 10
(4,851 Views)
Hi, same problem I had, I had to type yes not "y" and it worked. but now I get error couldn't find C:\phexec.exe. Did you get this or were you able to run Pharlap from your SSD/HDD?
Message 10 of 10
(916 Views)
