4
VBAI
Simulate acquisition
Import an image in from a .csv format (8 bit, 16 bit, float)
Just curious what the use case is? I assume this file would have a 2D array of pixel values?
Exactly. Many systems export their "images" as a 2D array of pixel values. Examples are height maps from frindge / stereo imaging sytems or thermal cameras. The values are most often floats or 16bit.
