I am posting Labview code to calculate the perspective projective mapping between two planes (homography), assuming that locations of at least 4 corresponding points are known. This can be used for pixel-to-real world mapping by eliminating perspective distortion, after which the measurements of a real world object can be performed. For example, the previous post describes the practical application of this (https://decibel.ni.com/content/blogs/kl3m3n/2015/03/13/optical-water-level-measurements-with-automat...).
Or you can just do some cool stuff like this
base image
images of koala and penguins (obviously
final image (koala and penguins subjected to perspective distortion and inserted into both base image frames).
I am attaching the Labview program to calculate the homography and perform a simple check of the result. The calculated homography can then be used for example to map the pixel-to-real world or pixel-to-pixel coordinates.
K
