today I am posting a full example on how to receive data in Labview that is sent from a microcontroller. The microcontroller I used for testing was Arduino Uno (the posted code reflects this), but in case anyone wants to use ARM based microcontroller (STM32 line, ARM Cortex-M) please let me know and I will update the code.
The microcontroler sends random byte data to the serial port and also calculates a 2 byte CRC which is appended after the end of each data package. Of course, the data sent can be anything - for example, the data read from an arbitrary sensor. You can modifiy the number of bytes sent and the number of bytes that are used to signal the data end (for explanation, see the full code below):
class GenerateAndSend {
public:
uint8_t data;
uint16_t crc_16;
static const uint8_t streamEnd;
public:
GenerateAndSend(void);
~GenerateAndSend(void);
void Reset(void);
void GenerateDataAndSend(uint8_t downLimit, uint8_t upLimit);
void SendEnd(void);
void SendCRC(void);
void CalculateCRC(uint16_t *pcrc, uint8_t *pdata);
const uint8_t GenerateAndSend::streamEnd(255);
GenerateAndSend::GenerateAndSend(void) {
GenerateAndSend::~GenerateAndSend(void) {
void GenerateAndSend::Reset(void) {
crc_16 = 0xFFFF;
void GenerateAndSend::GenerateDataAndSend(uint8_t downLimit, uint8_t upLimit) {
data = (byte) random(downLimit, upLimit);
Serial.write(data);
void GenerateAndSend::SendEnd(void) {
Serial.write(streamEnd);
void GenerateAndSend::SendCRC(void) {
uint8_t *pcrc_16 = (uint8_t*) &crc_16;
for(uint16_t i=0;i<2;i++,pcrc_16++) {
Serial.write((*pcrc_16));
void GenerateAndSend::CalculateCRC(uint16_t *pcrc, uint8_t *pdata) {
// Fast (LUT) CRC16 calculation update (one call, one byte)
// Byte table 0xA001 polynomial
static const uint16_t crc16_tbl[] = {0x0000, 0xC0C1, 0xC181, 0x0140, 0xC301, 0x03C0, 0x0280, 0xC241,
0xC601, 0x06C0, 0x0780, 0xC741, 0x0500, 0xC5C1, 0xC481, 0x0440,
0xCC01, 0x0CC0, 0x0D80, 0xCD41, 0x0F00, 0xCFC1, 0xCE81, 0x0E40,
0x0A00, 0xCAC1, 0xCB81, 0x0B40, 0xC901, 0x09C0, 0x0880, 0xC841,
0xD801, 0x18C0, 0x1980, 0xD941, 0x1B00, 0xDBC1, 0xDA81, 0x1A40,
0x1E00, 0xDEC1, 0xDF81, 0x1F40, 0xDD01, 0x1DC0, 0x1C80, 0xDC41,
0x1400, 0xD4C1, 0xD581, 0x1540, 0xD701, 0x17C0, 0x1680, 0xD641,
0xD201, 0x12C0, 0x1380, 0xD341, 0x1100, 0xD1C1, 0xD081, 0x1040,
0xF001, 0x30C0, 0x3180, 0xF141, 0x3300, 0xF3C1, 0xF281, 0x3240,
0x3600, 0xF6C1, 0xF781, 0x3740, 0xF501, 0x35C0, 0x3480, 0xF441,
0x3C00, 0xFCC1, 0xFD81, 0x3D40, 0xFF01, 0x3FC0, 0x3E80, 0xFE41,
0xFA01, 0x3AC0, 0x3B80, 0xFB41, 0x3900, 0xF9C1, 0xF881, 0x3840,
0x2800, 0xE8C1, 0xE981, 0x2940, 0xEB01, 0x2BC0, 0x2A80, 0xEA41,
0xEE01, 0x2EC0, 0x2F80, 0xEF41, 0x2D00, 0xEDC1, 0xEC81, 0x2C40,
0xE401, 0x24C0, 0x2580, 0xE541, 0x2700, 0xE7C1, 0xE681, 0x2640,
0x2200, 0xE2C1, 0xE381, 0x2340, 0xE101, 0x21C0, 0x2080, 0xE041,
0xA001, 0x60C0, 0x6180, 0xA141, 0x6300, 0xA3C1, 0xA281, 0x6240,
0x6600, 0xA6C1, 0xA781, 0x6740, 0xA501, 0x65C0, 0x6480, 0xA441,
0x6C00, 0xACC1, 0xAD81, 0x6D40, 0xAF01, 0x6FC0, 0x6E80, 0xAE41,
0xAA01, 0x6AC0, 0x6B80, 0xAB41, 0x6900, 0xA9C1, 0xA881, 0x6840,
0x7800, 0xB8C1, 0xB981, 0x7940, 0xBB01, 0x7BC0, 0x7A80, 0xBA41,
0xBE01, 0x7EC0, 0x7F80, 0xBF41, 0x7D00, 0xBDC1, 0xBC81, 0x7C40,
0xB401, 0x74C0, 0x7580, 0xB541, 0x7700, 0xB7C1, 0xB681, 0x7640,
0x7200, 0xB2C1, 0xB381, 0x7340, 0xB101, 0x71C0, 0x7080, 0xB041,
0x5000, 0x90C1, 0x9181, 0x5140, 0x9301, 0x53C0, 0x5280, 0x9241,
0x9601, 0x56C0, 0x5780, 0x9741, 0x5500, 0x95C1, 0x9481, 0x5440,
0x9C01, 0x5CC0, 0x5D80, 0x9D41, 0x5F00, 0x9FC1, 0x9E81, 0x5E40,
0x5A00, 0x9AC1, 0x9B81, 0x5B40, 0x9901, 0x59C0, 0x5880, 0x9841,
0x8801, 0x48C0, 0x4980, 0x8941, 0x4B00, 0x8BC1, 0x8A81, 0x4A40,
0x4E00, 0x8EC1, 0x8F81, 0x4F40, 0x8D01, 0x4DC0, 0x4C80, 0x8C41,
0x4400, 0x84C1, 0x8581, 0x4540, 0x8701, 0x47C0, 0x4680, 0x8641,
0x8201, 0x42C0, 0x4380, 0x8341, 0x4100, 0x81C1, 0x8081, 0x4040};
(*pcrc) = ( (*pcrc) >> 8 ) ^ crc16_tbl[( (*pcrc) & 0xFF ) ^ (*pdata)]; // Process 8-bits at a time
GenerateAndSend streamData; // Object
void setup() {
Serial.begin(115200);
void loop() {
streamData.Reset();
for(uint16_t i=0;i<5;i++) { // Data
streamData.GenerateDataAndSend(0, 255);
streamData.CalculateCRC(&streamData.crc_16, &streamData.data);
for(uint16_t i=0;i<3;i++) { // Send End (number of times must be synchronized with the receiver)
streamData.SendEnd();
streamData.CalculateCRC(&streamData.crc_16, (uint8_t*) &streamData.streamEnd);
streamData.SendCRC(); // Send calculated CRC
delay(100); // Delay
I tend to separate the class declaration and members definition in different files (.h and .cpp), but this example is simple and more readable this way.
The Labview code uses a producer, consumer structure. The producer loop reads one byte at a time and checks for data package end. When the data package end is recognized, two additional bytes are read (the CRC). The consumer loop then performs the CRC check and outputs the data stream.
The Labview code could be made more readable by packing some portions into subvi's, but it seemed simpler to present the example in this manner.
I am also attaching the C++ code for Arduino as a .txt/.ino file and the Labview code saved for version 2013. Again, if someone needs the ARM code, please let me know and I will update the post.
K
