I am writing this mostly as a reminder to myself!
Next projects:
- building and testing a mini laser scanner using a line projector. This will be a scanner for small objects (actual dimensions not yet known) with budget under 100 eur. Software (hopefully) will account for both camera (fairly simple) and projector distortion (hmmm).
- using MLX90620 IR temperature sensor and Arduino to display temperature measurements in real-time on Android compatible device.
Side projects:
- Testing Labview CUDA library
- Testing Labview Stereo Vision library (http://forums.ni.com/t5/Machine-Vision/Stereo-library-2012-pointers/td-p/2171812)
The order of the execution is not known.
Be creative (also note to self)
https://decibel.ni.com/content/blogs/kl3m3n
Kudos:
Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
