Well, it is a corner case, but I somehow ran into the situation, that the xml metadata at <LabVIEW Data>\DQMH Module Templates\ defined a name for the API tester which was not correct, resulting in an error 7 message
Please add the path, which the scripting is trying to copy to the message, as a first hint.
Adding a note to check the XML would be a second nice hint for the user.
Offtopic: Lastly, I wonder, why the name of the API Tester needs to be present in the XML at all. I was expecting that the module validation fails, if the tester doesn't match the naming rule, which is also applied, when a module is being renamed. A quick test shows, that my assumption is not correct: The API Tester of a module can be named randomly. I am pretty sure, I have applied Fixes to API Testers via the validation dialogue in the past and I wonder how that works, if the naming rule is not required 🤔
Accepted for a future release.
