8 | |
5 | |
4 | |
3 | |
3 |
The scroll bar in the string constant is literally useless since whenever I try to scroll things inside the string constant the constant moves and not the content. So it would be good if the user focuses the mouse pointer in scrollbar and makes a click the string constant should not be selected letting the user to scroll the text inside the string constant.
Moved to CAR database: CAR 598986
