Community Browser
Top Authors
Post an idea
Wouldn't it be nice to just check/ uncheck existing sub-VIs of parent classes in the Inheritance Dialog Box, since all of the sub-VIs in child classes have to have the same name anyway. Instead of manually add them one by one.
With only a few VIs and a few child classes the saved work is huge.
PS: I did not find a similar idea here, so bare with me if it already was put up. The AES guy at the UGM did not know about anything easier then copy and paste at the level of WinExplorer and later add the files to the project.
It would be very useful if we could have same QuickDrop PlugIn with the same shortcut depending of the selection object that we have made in "Block Diagram" or in "Front Panel".
For example:
- Imagine "Ctrl+C" short cut, this would be useful for lots of QuickDrops that comes to my mind.
  • Copying to clipboard a bundle by name text.
  • Copying to clipboard a unbundle by name text
  • Copying to clipboard a selected case.
  • etc....
It would be useful to have a configurable tool for generating swept values for RFSA/RFSG mainly.
This is actually present in Signal Express. You can insert and even nest the "sweep"-step here, but as far as I can see SigEx doesn´t have support for RFSA/RFSG.
So the next thing coming to my mind was to export the configured sweep as LabVIEW code from SigEx. Unfortunately the resulting Express VI cannot be converted into a regular subVI.
It would be very useful for debugging and prototyping to get this feature!
kind regards
Marco Brauner AES NIG Munich
Why doesn't LabVIEW Provide any Simulation for real time hardwares.... What i mean to say that Just as if we build some hardware circuits using microcontroller ... We can simulate the values in almost actual environment using some simulation software such as proteas.... I came up with this when i tried generating a PWM Signals as i ordered the Digital I/O card from LAbVIEW which did took time for shipping...
Add "Calculate Statistics" Enum to "Write to Spreadsheet file"
<Bye row,  Bye Col, Bye table,  Bye both Row and Col...>
The staticistics are nice to know... and certainly can be calculated from the 1D or 2D data input to "Write to spreadsheet.vi"
We just need an enum to add the evaluation of the datapoints.
At the moment there are two wait functions in LabVIEW that I know of:
-wait (ms)
-wait until next ms multiple
I propose a third option, 'wait until ms timer value' which waits until the system timer reaches the specified value.
What does this gain us? Suppose we want a loop to execute on the average every n milliseconds. We use the existing 'wait next ms multiple' in the loop. What if we want n to be non integer? It may not make sense to pass a fractional number to a wait function that doesn't offer that resolution, but it's a reasonable wish to have a loop execute on the average every n milliseconds for non integer n. How can we achieve this? Add n to a count each time we loop, then each loop wait the whole part of this accumulated value and take this off the count. The result would be a loop which takes sometimes a little under, sometimes a little over the specified number of millis due to rounding, but averages to the non integer value requested. The problem is the required wait function- wait(ms) will not do it- it doesn't account for the time the code in the loop takes to execute. Wait next ms multiple won't do it- it's no good when the wait is varying - what we need is to wait until a fixed timer count.
Hence the request.
It would be helpful if the IMAQ Particle Analysis VI took as inputs:
Max Number of Particles
Maximum Analysis Time
It could then use these parameters to decide when to quit processesing the image and report back that it did not complete the operation via a boolean output or enumeration that indicates why it did not complete the processing.
In an automated vision system used count defects it is possible that the sample under test has an enormous amount of defects.  In that case the user might want to call the sample grossly defective and they do not care if the exact number of defects (particles) are reported.  Likewise, if the automated system has a fixed time frame over which it needs to process a sample this input would guard against that time frame being exceeded.
How about a plugin for doing vi analysis to check whether our vi follows the style rules of Labview?
Something like StyleCop or FxCop for C#.
The Current Situation:
In a LabView Real Time program Control References cannot be used because the front panel is removed (even if debug mode is enabled). In order to write to a control in a cluster, the only options are to use unbundle/bundle or variants. It is preferrable to be able to programmatically write to any control within the cluster when one is required to be able to change any value within a large multi-level cluster that has many controls. Using variants and drilling down into the cluster to access and change a value causes execution issues in a Real Time program.
The Idea:
Have a Control Reference Terminal on the Data Value Reference Read Node on the InPlace Element Structure. This is shown in the code below.
This would allow the value (and whatever other properties make sense to be accessible) to be programmatically modified inside the InPlace Element Structure. This would work in the Real Time environment too.
Labview has a way of creating the equivalent of static variables in a VI similar to static variables in OO languages or function-scoped static variables in C. This way is through the use of uninitialized shift-registers in single-iteration loops (i.e dummy loops).
If multiple instances of a VI is created and the VI contains such a static variable, the value of the static variable persists from one instance to the next. I can see why this is useful, but I think it would also be useful if there was an option to make static variables of different instances of a VI separate.
Static variables are primarily useful for VIs that have some concept of state and you don't want to explicitly create a state variable or cluster that the user has to manually feedback with outside signals. For example, if you created a VI for a PID controller or a state machine, and you wanted to use an uninitialized shift register to store that state, you can not create multiple instances of that VI with out having the two instances intefere with each other. The two instances cannot maintain independent state.
I ran into this problem while creating a VI to implement a moving window of values. (as a side not, it would be useful to have a moving window VI)
Granted that I’am a new user of LabVIEW 8.2, I wonder if you could define the parameters skweness and curtosis not only using moments but also using K-statistics (there’s a bit difference).
I apologize for my English.
Luca De Vecchi
The second element in the ROI cluster is an array of Contours yet many sub vis will only act on the first contour in the array. Both the required contour descriptors(line and annulus) are available in the example image, but since the first element is a line, the circular edge find - which wants the annulus - throws an error.
All it would take would be a simple index and logical test to fix this issue.
Ich hätte gerne die Möglichkeit, in einem Diagramm mit 2 Y-Achsen 2 Graphen darzustellen,
die unterschiedliche Einheiten haben, z.B.: Spannung[V] und Volumen[m^3]
I have been working a lot with the Microsoft office add-on toolkit for report generation and noticed a few missing functions. One thing was that if you had a template that has tabs in the workbook that were charts ( when asked where you want to display the data when creating a graph you have the option for in the worksheet or in a separate chart) the worksheet selector does not recognize these tabs. So if you needed to change the worksheet name based on say a test name or configuration it will just skip over the tab. Or if you wanted to change the data going to the graph it will not let you select it with the select worksheet sub vi in order to further process it.
A second problem I had was replacing the Title of a graph in excel sheets. Apparently you can only manipulate graphs created by Labview using the toolkit. Ones that are already present in templates that are loaded are not changed by the toolkit functions. This means graphs are pretty much useless unless you write a lot more code that grabs data from sheets and creates graphs in different workbooks. It can be done, but for a workbook like mine that had 64 tabs it can be a nightmare. Just a thought I had that would save a lot of time and be useful for a lot of people interested in manipulating excel sheets and doing post processing on them. Still love Labview though.
Using the Distortion Meter and Spectrum Analyser for measuring signal distortion will give a definitive numerical value, but what does the distortion
look like? In the case of a sinusoidal waveform, is it clipping or crossover distortion for example. This needs to be known so one knows which part
of the circuit design needs closer inspection.
One can, as I often do, use a resistive network to sum an output signal to a reversed polarity input signal. However, it is a real pain adjusting the
two signals to balance to a null at the resistor centre point. Ah, you might say, use the differential  inputs of the Oscilloscope to subtract the signals
and view the error. This has two gotchas. One being there is no variable Y gain on the Oscilloscope to finely null the two signals, the other problem
is there will more than likely a time/phase difference between the inputs, thus preventing complete cancellation.
For the above reasons, if the Distortion Analyser had an output which showed the residual signal upon which it’s distortion figure is measured,
I would be a very happy bunny.
Ooh, whilst I am here, if an NI MultiSim developer happens to have nothing to do for a day or two, could a variable gain be added the Y input attenuator
of the Oscilloscope?  🙂
Keith
For those measuring differential signals, having balanced inputs on both the Spectrum Analyser and the Distortion Meter would be an invaluable asset.
The Oscilloscope has this mind boggling feature, would so useful if it were added to the afore said instruments.
Keith
I was wondering if anyone else would like to see some bootstrapping and permutation test functionality added to labview.  I find myself having to use MatLab's statistical toolbox which has a solid amount of statistical resampling methods.
In the series "Intended versus expected" (or blue versus orange), this is a discussion of a not very helpful feature of the Ramp Pattern VI:
If you ask for a single sample (samples = 1) from the Ramp Pattern AND do not set "exclude end?" to True, the VI returns an error -20006: "Analysis:  The number of samples must be >= 2."
The Help specifies that: " If samples is 1 and exclude end? is TRUE, the VI returns an array with one element of start."
It doesn't say anything about the situation I described previously, but most likely the error comes from the likely following definitions of the array {xi} of values (in the linear case):
1) exclude end? xi = xs + i*(xe-xs)/N, where i = 0,..., N-1 and (xs, xe) are the start and end points respectively
2) do not exclude end: xi = xs + i*(xe-xs)/(N-1).
In the second case, N = 1 results in a division by zero, hence an error.
So far so good, but here is the catch: Suppose I want to build a curve with equidistant abscissa (number N), comprised between a start and end points xs and xe (both included). It seems like the Ramp Pattern has been designed for me, right?
Wrong. If I set xs = xe and N = 1, I would expect a single point, equal to xs = xe. Instead, I get an error. So my first contention is that this should be a detected case: xe = xs AND N = 1, should result in a single element array equal to xe = xs.
Now, what I would suggest is that if xs != xe AND N = 1, then the Ramp Pattern could return a single element equal to (xs + xe)/2 (and a similar definition for a logarithmic ramp).
I've posted an idea, but didn't add any pic to explain:
http://forums.ni.com/t5/ideas/v2/ideapage/blog-id/labviewideas/article-id/16975/tab/rich
I've attached an image with this idea. Sorry for the duplicate posts.
These are simple examples but can get more complicated. For example, usage 2 can have more input (e.g. 4) it will have 16 possibilities which have different simplified code.
USAGE 1: User wires some input on the block diagram, when the simplify button is used, it simplifies the complicated code to a simple one ( noting that it is not the unique solution as shown in USAGE 3)
USAGE 2: If for the application, the user changes the value of the input and he gets different output; this table can get the simplified; or the "best fit" for the number of data present.
In http://forums.ni.com/t5/ideas/v2/ideapage/blog-id/labviewideas/article-id/16975/tab/rich, I wanted to compare that  Partial fraction expansion vi is not widely used except for certain applications yet it is important and beneficial.
Same goes for this idea.
Best
There are alot of applications that require the use of Booleans, and when the boolean expression gets complicated or large it will be a headache on the programmer.
LabVIEW should try having a De Morgan law "function" or at least a way to simplify complicated Boolean expressions. Although it won't be used as much, it will be a handy tool for any electronics/programming course.
For instance, Partial fraction expansion isn't used regularly but when it's used it helps save time.
