Community Browser
Top Authors
Post an idea
It's good to have tool like Quick Drop...........but it will great if we can see our own VIs/Custom Controls/Custom Indicators/objects present in my PC in the list.
This can be achieved by remembering them while they are made or being used for the first time. So that every time I don't have to got to Select Vi, search the path & call a VI.
The only option to do this right now is by placing the VIs in user or inst directory of Labview.
But this not what we always do right? We manage the folders & VIs in different locations.
Just as good function as any desktop search.
I would suggest that NI makes the datatypes of the "Quotient and Remainder" VI consistent.
If you now wire a double to the VI the outputs are of the datatype "double" however in my opinion this is not consistent with the mathematical definition of quotient, floor(x/y) and remainder, x-y*floor(x/y). The output of the VI is always a integer and should therefore also be of that datatype, thus one of the following datatypes (I64, I32, I16, I8).
I had a customer call in that wanted to be able to increase the limitation that Excel allows us to import. He has found a work around in which he creates a Visual Basic Macro in excel. He uses Active X in LabVIEW to open excel, and this puts the macro into use and overwrites the limitation. He was hoping that LabVIEW could do this for him and others so he would not have to write separate code in Visual Basic.
VI Analyzer complains if you use the Build Array function or Concatenate Strings function in a loop because these functions negatively affect memory and processor usage in a loop. Using both of these functions in loops bring certain advantages to code. Primarily, you can dynamically build strings or arrays, which is helpful because sometimes it is hard (if not impossible) to know how big a string or array is going to be when a loop is run.
The first image below shows a loop with both of these functions that will cause a memory leak as the loop is run.
Build Array and Concatenate String in Loop - Will Cause Memory Leak
I got to wondering... Is there a way to dynamically build arrays and strings in a loop that will not cause a memory leak? In my limited testing, it looks like the code in the second image performs the same function as the build array and concatenate strings functions, but without the poor memory performance. I can run the code below for long periods of time and not have a memory leak. The instant I switch over to the case to use Build Array and Concatenate Strings the code beings to chew up memory. My idea is this: Replace the internals of the Build Array and Concatenate Strings functions with the code boxed in red in the image below. It is preferable that the code below gets contained in its own function because it clutters up any diagram with the extra nodes.
If putting this code into the Build Array and Concatenate Strings functions is technically possible, it will allow people to dynamically build arrays and strings in loops without the costly memory performance. One note is that the code that builds an array in the second image is scalable, but the code that builds a string is not scalable. If this is implemented, the code to build a string should be scalable, but based on the code below that does not cause a memory leak.
Replace Build Array and Concatenate Strings with the Code Boxed in Red
In many of my programs, it is frequent that I have to issue a command, then wait for a period of time before reading a response. Usually, if there is a timing delay in code, it is usual to end up with something like this:
To do this more neatly, I created a timing subVI with errors wired in and out, and a number wired to it, to instruct the program to stay in that subVI for that period of time. It takes up much less space.
By doing this, I can easily control timing and execution. However, it's be nice to rework the 'milliseconds to wait' diagram so we could wire errors through it, as this would make the block diagrams so much neater...
I am finding labview execution speed to be extremely slow.  I seem to recall documentation indicating that labview passes all data/variables by value by default.  I think that if labview would default to passing data/variables by reference instead of by value, then execution speeds would greatly improve.  Is there an option that would allow one to change this?
I've recently run into an issue when using external code (ActiveX to be exact) where I needed to explicitly call garbage collection in a similar fashion to how it's done in C# (C Sharp).
The "Request Deallocation" function isn't true garbage collection.
A C# example would be:
someComObject = null;
GC.Collect();
There are situations where it is neccessary to explicitly call garbage collection.
Multi-Threaded Interrupt Management Capabilities in LabVIEW
Background
            Event interrupt management works well in LabVIEW if ones’ programme is small and developed within a single overall Event Structure, encapsulated within a While Loop.
            The problem comes when the software architecture demands a separation between the User Interface management (interrupt) functions and the sequential and looped programme structure (executable) components of the code for modular programming. In this configuration, waiting for Events to occur before code execution, pausing code execution (once started), stopping code execution or even aborting code execution (with the ability to close the application down cleanly prior to code exit) become challenging operations to implement within LabVIEW.
            This software architecture design challenge is exacerbated, if branching within the looped programme structure (executable code segment) is also a requirement.
Two Key Requirements
            Ideally, the following two capabilities, if implemented within LabVIEW would solve all of the aforementioned problems:
  1. To be able to interrupt a While Loop, pause it and if appropriate reset the [i] loop index back to zero. If controlled via the Event structure, this would make both Event structures and While Loops compatible with each other, which is not the case today.
  2. To be able to interrupt a Flat Sequence or Stacked Sequence structure and break out at any individual “Frame” in that structure, based upon a specific Event interrupt or even an Abort, which when controlling hardware can be a critical request that requires immediate action! Today, it is not possible to break out of a Flat or Stacked Sequence structure, one has to wait until the complete Sequence has executed.
Current Tools
            Current LabVIEW, if used with care, can overcome to some extent the current While Loop and Flat Sequence software architecture limitations, but they are very cumbersome to use and require an "eagle eye" and good software tracking and debugging skills!
While Loop with Pause and Stop buttons
Set Occurrence
Wait on Notification (Front Panel activity)
A not yet fully complete explanation of the key multi-threaded programming issues is attached. If it requires updating to make it complete, do let me know.
Will be good when running an application in debug, keep other LabView project enable and editable, so I can continuous to work under other project waiting the debug stop at break point
I don't know if this idea belongs in the "LabVIEW" Ideas Exchange necessarily, but this idea is something that would really make a big difference to my LabVIEW development, so I offer it anyway: "Parallelise the FPGA Compiler to take advantage of modern multi-core computing power".
The FPGA compiler takes approximately four hours to compile my large FPGA VIs, which makes for long and tiresome debugging processes. It's clear that the compiler uses only one core of my CPU when compiling. If the compiler could be written to take advantage of the many cores of today's multi-core computers, it could potentially reduce my compilation times to an eighth! (Where I work we have an eight-core number crunching server ideal for just this task, and I'm sure we'll get even greater core counts in the near future - thinking GPU here).
I know the compiler is probably the intellectual property and responsibility of Xilinx Corp, and not National Instruments, but I expect NI can give them a big push if we all asked nicely for it!
Thoric
Its better to disable the functionality of the function keys while a code is running.
One incident i came accross is:
     I assigned ESC key for a control and while running the code i wrongly pressed F1 (Which is not assigned to any control) suddenly the Help file started opening and my whole code got hangged. I dont think that some one will need open the help file during code running So its better to disable the original functionality of the function keys just during the code is running.
Smiley Wink
After deciding to post an idea for a "parallel" structure, a search revealed the idea for a Parallel Execution Structure has already been proposed by gvholland here
I gave my kudos to this idea because I believe it would be very useful.  In order to make a parallel structure even more useful, I propose adding some features that would make it more convenient for those of us who might use it in code that must execute in parallel for performance and functional reasons.  It has been commented on the other thread that parallel code should be placed in subVI's, and I concur with this view.  However, there are instances where this is either inconvenient or impracticable.  Consider the following example:
An application needing to perform simultaneous PID control on 32 channels must execute in parallel (only 8 channels shown for clarity):
23998iF3A3D6145B22A221
Now quadruple the number channels in this scheme, and you can have a pretty big diagram with lots of wires.  Also consider the routine task of initializing that “clustosaurus”  or “classosaurus” as in this example:
24000iDFC8181255144D80
We've all probably tried the scheme wherein we put a case structure inside a FOR loop and wired the iteration terminal to the case selector, as in these examples:
24002i0E33EE6CA3D6316A
24004iB398DF500188AD49
That's clean and easy, and allows the user to create instances of the reentrant VI by duplicating cases.  But that architecture forces the vi's or code to execute sequentially.  The new parallel FOR loop can boost performance of these techniques, and create parallelism.  But I would like a basic parallel structure that cleanly handles some routine tasks by adding some useful I/O nodes, ala the InPlace Element Structure.
I propose the following structure, or something similar:
24006iEFA2DE50585DBE3A
This structure is drawn here with some proposed I/O nodes and tunnels.  This is by no means the complete set of I/O that might exist, but rather a starting point.
Cluster unbundle/bundle node:
 24008iB135E86434F20934
This node accepts only “brown” clusters, or clusters of Booleans.  The elements are passed to each frame in corresponding index order, element 0 to frame 0, and so on.  Once added to the structure, a single unbundle/bundle terminal pair appears in each frame. Much like a bundle function that has its center terminal wired, the bundle terminals may be left unwired.  The values of unwired elements remain unchanged.  Any cluster wired to this node must have the same number of elements as the parallel structure has frames.  If not, the wire is broken.
Array index/replace node:
24010i570ABF83C7044CDA
This node auto indexes an incoming array and provides a replace array element node on the right.  Note there is no index value IO as with the IPE, since the parallel structure auto indexes the array and distributes/replaces the elements across the frames.  If an array has less elements than the number frames at run time, the node returns default data for the undefined elements, exactly as an index array function does, but the structure returns a warning or error (I can’t decide which).  The output array would always have the same number of elements as the structure has frames, or the same number of input (can't decide which) .  The replace element node on the right must be wired in every frame, just as a replace array element structure must have all of its exposed elements wired.
Cluster unbundle/bundle by name node:
24012i2C2666661000FEB0
24014i1D92D4684B152FC9
This node is tricky, but I decided to take a stab at it anyway.  The node is created and visible on both sides of the structure.  However, unlike the IPE, the unbundle/bundle terminals on either side can be of different sizes and element selections, and can optionally be unused on either side, or both sides, within the individual frames.  Unused terminals appear with the same symbol as the center terminal of a bundle function, as shown in the proposal drawing.  If an element is selected for bundling within a frame, then it is unavailable for bundling in all other frames.
Indexing and non-indexing tunnels:
24016i58EE71B2884A8F01
Non-indexing tunnels function somewhat like they do on a sequence structure.  Input tunnels provide data to all frames, non-indexing output tunnels may only be wired in one frame.  Unlike sequences, however, the data arriving at output tunnels would be free to flow out of the structure immediately, which will seem weird, and violates the "whole structure must complete" convention.  But remember, this is a parallel structure.  Like sparks shooting off the bolts in the monster's neck while it's alive, it's gonna be be weird by default.
Indexing tunnels are different.  Like the auto-indexing node, auto-indexing input tunnels distribute the array elements across the frames.  If the array size is smaller than the number of frames, the frames either execute with default data, or the undefined frames don’t execute, and the structure returns an error or warning (help me define this).  Auto-indexing output tunnels behave like output tunnels from case structures; either all frames must be wired, or the tunnel must be configured to use default data if unwired.  Unlike the non-indexing output tunnel, data from this tunnel is not available until all frames have completed execution.
Error I/O Nodes:
24018iB1B7660563C17E73
There are error inputs/outputs for the structure as a whole, and for each individual frame.  The structure error IO is situated in the lower left and right corners, naturally.  The frame input and output terminals can both be optionally hidden or exposed in each frame, and also slide independently of each other up and down the left and right sides of each frame in which they are exposed.  The structure distributes the incoming error among the exposed frame error input terminals, and merges the frame output error values to the structure output terminal, along with any messages generated by the structure itself.
So what do you do with this “Frankenstructure”?  Well, here are a couple of the aforementioned examples rewired using this hypothetical beast:
24020iFA3810D047850DB3    24024i4CB073DB117956CF
Of course there could be other cool things, like a CPU core selector for the frames, etc.  Just let your imagination, (or nightmare, depending on how you see it) run wild!
Currently I'm busy with GOOP and I came across the following problem.
I have a validator class. The purpose of this class is to validate data. The validator class as a number of childrens...
Validate IP address
Validate string length
Validate inRange number
Validate Alpha
The main, validator, class has a function called "valid?" This function has 3 inputs and 3 outputs
Inputs:
- Object
- The data that must be validated
- Error
Output:
- Object
- Valid?
- Error
The children classes must inherit this function and overwrite it. Now the problem is is that each of the above validators have a different datatype which must be validated....
Validate IP address has a string as input
Validate string length has a string as input
Validate inRange number has a number as input
Validate Alpha has a string as input
Now you might see the problem. To get the children to inherit the function from the main, validator, class the connector pane must be the same as of the datatypes... This means that I have to choose in my main function to use a string or a number as input... This is something that I don't want... I want to be able to select a datatype called "yet unknown datatype" in my main "valid?" function in the main, validator, class. So that I can use any datatype input in my children that is suitable for that implementation.
My idea is thus to create a new kind of datatype which sort of represents "any kind of datatype known to labview" which can be used in functions of a main class that are inherited by its children, which are all using a different input datatype.
ps. Now you could maybe suggest why not use a variant datatype? Yes this is possible but the problem is;
- I would have to cast the data back
- It isn't very neat programming, the variant solution is in my opinion more a kind of hack to make the code work.
pss. Yes but if you would do this... then...
- Yes there are proberbly a few more work arounds thinkable, such as creating two "Valid" VI's one inherited (Valid?), one unique of the child (_Valid?), but these are in my opinion still workarounds and do not really provide the functionality that is needed. Which is pretty common in OOP languages.
psss. if anyone knows a better title for this described idea let me know it!
Enable a Sub VI to launch as a daemon without having to open a reference to it using its path.  The VI Properties page would look like this:
21429iB830C4B88A795136
Wait until done would be checked by default, and auto dispose reference would be left false be default.  So instead of parsing the path to the VI on disk and using a method to run it:
21433i0CFC0F873277247C
I just set the correct properties in the VI Properties page and drop the subVI on the block diagram of the calling VI.
the idea subject says it all. I think this is usefull for multi-level data types with data placed into the parent and its child class (and in the child of the child class ...). To transport the data, you use the parent class. If you want to modify the data inside of a child class, you program a corresponding dynamic dispatch VI or you have to convert the parent class to its child class, modify the data, and convert back to parent. The In Place Element Structure would be nice for the second method.
Marc
I was just involved in a discussion about a default return value for the dequeue primitive when a different idea struck me.
Why can't we define a default value for typedefs.  Especially enums would benefit by having a case reserved for operations where something didn't work as expected and a default value is returned.  Being able to seperate this value from other (normally required) values would be a boon for ensuring data integrity.
21307i98E925E66B45E54C
Why can't we have the default value set to something we don't normally interpret as being valid?
Issue:
Dynamic Launching of a VI works fine when the plug-in code is launched from the LabVIEW source code.
When the Application was build it fails to launch the VI. Upon debugging I found that I am reusing some of the SubVIs in the plug-in VIs that is part of the EXE. I tried renaming and re-linking of those Vis for the Plug-in VIs it works fine.
Solution:
           Similar to Name spacing provided by Lvlib files. Add an additional option in the Exe build spec, to add a name space for the application this will rename all the VIs as "my project:main.vi, My project:test1.VI" etc inside the Exe. This will resolve the naming issue created by the LabVIEW runtime engine. So a plug-in VI can reuse the test1.Vi from the Source code.
I have had to jump through hoops to create a .net process or use runas to get portions of code to run
when the end used does NOT have admin privileges.
Add Option under VI Properties >> Execution to allow setting the VI to run as admin or another user.
In their current form, Auto-Indexing tunnels only operate on a single dimension of an array.  For example.  If you input a 2D array, through an auto indexing tunnel into a for loop, and display the resulting 1D array in an indicator inside the for loop as below, you will always get the last row.
I'd like to see a feature where you can right-click on the tunnel or something, and set it to auto-index by column, instead of by row, and get the last column instead.20773i86B483107F51CD3820775i651136B201680B64
It could be as simple as an option in the context menu for the auto-indexing tunnel to say "Index by rows" or "Index by columns"  It gets more complex with 3D 4D and moreD arrays, but you could do something like a submenu flyout that says "Index By Dimension" > "1", "2", "3" etc
Loop indexes max out at 2,147,483,647.  It would be nice to have an option to wrap around the loop index instead of having it remain constant, in the event that you have a process that depends on that loop index incrementing.
