Community Browser
Post an idea
LabVIEW could use a feature that's commonly used in C++, the "final" specifier for a class override method.  This would allow a child class to override a method from a parent class (or interface) and then prevent child classes of itself from overriding.  Currently, with large inheritance structures, it becomes difficult for developers to create child classes since so many of the methods can be inherited from.  The final specifier would allow you to create intermediate classes that define certain override functionality that does not need to be further overwritten and only pass on the ability to override methods that are important to child classes.
When indexing a map on a for loop, the indexing is automatically done by ascending order on the key value.
I like this as a default behavior.
I'd like to have a context menu option to force the for loop indexation to be done in reverse order.
Please address the problems/shortcomings when setting file security permissions in Windows File I/O. The current Get Permissions and Set Permissions File I/O vis do not work.
Currently when LabVIEW creates a file it assigns the default security permissions, which are inherited from the parent directory. This is a pain as the current user is allowed, in general, read and write access, but other users are potentially only granted read access. For example, creating files in the public application data directory (as the sample projects demonstrate for storing settings) means that only the user who first created the settings file can update its contents, whilst other users will get a file permission error.
At minimum, I would like to be able to specify what kind of access other users should have when creating a file. Better still, I would like to be able to get and set security info. Currently I am forced to call functions in advapi32.dll to set acceptable permissions (e.g. GetNamedSecurityInfoA).
I am not the first person to encounter this limitation (see, for example, https://devs.wiresmithtech.com/blog/config-files-in-labview-locations/).
I would like to watch the series of videos from 2012 about learning Advanced Architecture.  I would like to follow industry standards to ensure that I am building an architecture that will be understood by developers.
I did a bit of research and somehow I managed to unlock the course as a student.  I went back to finish the course today and it switched to "you are not entitled to training courses".  I mean fair, but I feel pretty entitled to steer people away from LabVIEW if they come to me with interest in it...
I'm not understanding how this model can possibly make more money than having more LabVIEW developers.  Easy access to training = more developers = more hardware purchases and certification puurchases right?  Am I missing something or is this model as bad for share holders.
FIR Filter is almost the same as convolution, except that it has a init/cont terminal while convolution has an input for algorithm (Direct, frequency domain). FIR filter always uses direct convolution.
If "cont" is not used, convolution based FIR filtering could be orders of magnitude faster because it scales much less steeply with input sizes. Examples have been discussed where switching algorithms from "Direct" to "frequency domain" can turn minutes into seconds (e.g. 1M points and 5k filter).
While the knowledgeable programmer can of course make his own using the convolution primitives (also programming around other limitations because this idea is not implemented :(), it might be more intuitive if the FIR Filter had an "algorithm" input where we can select between the same choices as for convolution. (From my casual understanding, "frequency domain" would ignore the "cont" input because it is incompatible. This can just be mentioned in the help.)
Problem:
in many cases after wiring in the loop , we will go for the shift register to store variable. but in case of changing the loop tunnel to shift register left side tunnel required to connect manually.if not it creates the another tunnel in the loop.
solution:
in the loop , if the left and right tunnel variable are same , LabVIEW automatically replace tunnels with the shift registers.
Hi community
"propose to extend hashing function to include string for hashing sensitive information (1-way)"
currently hash function is polymorphic and accepts only path as input, perhaps:
- input terminal can accept both string and path, determining type internally and change accordingly, and
- instead of polymorphic, enum terminal instead?
When working on VIs that require large arrays or images for input, I often need to run a calling VI rather than the VI I'm currently working on, which involves a lot of tabbing between windows and clutter from having more open windows. I realize it is possible to set default values for controls, but I would rather avoid that as I often use optional connections to my SubVIs and therefore don't want to change default values.
In my opinion it would be useful to have the option to configure the run button to run a different VI than the currently open one, when working on VIs specifically developed to run as subVIs in the context of a higher-level caller.
Windows 10 now handles long file paths although it has to be enabled with via various possible registry or group policy edits. Windows applications have to opt in. LabVIEW source code should be able to utilize long file paths.
We could add a way, for example a parameter key in INI file of LabVIEW.exe, in order to run LabVIEW.exe silently, so without the splash screen and the getting started window, like a background process.
Example use case:
When you execute a build specification thanks to LabVIEWCLI (operation name: ExecuteBuildSpec, https://www.ni.com/docs/en-US/bundle/labview/page/predefined-command-line-operations.html), it runs LabVIEW.exe to complete the request. LabVIEW.exe is opened with the splashcreen and the main window. It's terrible, I want to use LabVIEWCLI to do some operation programmatically and silently (background mode) from my code/app.
If I have an existing cluster in my project and one day I decide to delete one of the elements of that cluster, LabVIEW tries to fix all the references or black them out to help me find the errors.  However, It seems that LabVIEW in some instances keeps track of clusters internal controls with an index and when you delete something, those indexes are now messed up.
For Example, if you have a property node linked directly to an item within that cluster, then you delete an item in that cluster, the property node now points to something else.  OOOPS!
Also, if you have an Event Structure Case pointed to a control within this cluster, and one of the other controls in the cluster get's deleted, this Event structure case now points to the wrong thing!
LabVIEW is internally keeping track of the controls in a cluster with an index.  It works fine as long as you only add new stuff to the cluster.  But if you delete things, LabVIEW does not handle it well.
If LabVIEW instead had a notion of the name of the items, then it probably could recover well when an item was deleted from a cluster.
NXG needs an Idea Exchange.  The feedback button is a lame excuse for a replacement.  Why?
  • I can't tell if my idea has been suggested before.  (And maybe someone else's suggestion is BETTER and I want to sign onto it, instead.)
  • NI has to slog through bunches of similar feedback submissions to determine whether or not they are the same thing.
  • Many ideas start out as unfocused concepts that are honed razor sharp by the community.
  • This is an open loop feedback system.
Let's make an Idea Exchange for NXG!
On a For Loop that is configured to have parallel iterations there is a nifty feature when using errors on a shift register.  This feature is explained in an article here.  It basically ensures that For Loops that run 0 times, will preserve the incoming error as if the tunnel was a shift register.  However this feature also means that errors from iteration 0, won't be passed into iteration 1.  What is returned if the loop runs 0 times is just the incoming error.  But if it runs for more than that, the errors are all merged and returned will be the first error seen.
This idea is just to allow this already existing feature to work on non-parallel configured For Loops.  When would this be useful?  Say I want to delete an array of files.  I want to attempt to delete all files, even if there is an error in trying to delete some, just keep trying to delete the other files.  Initially you may think this:
But that has the clear problem that if the incoming array is empty, then the error will be cleared.  So we often do something like this.
And honestly this bit of code isn't that big of a deal, but this feature already exists.  However it only works on For Loops that are configured to run iterations in parallel.  In this case I might be attempting to delete files in a specific order due to their placement on disk, and running in parallel isn't what I want.
Since not everyone wants all errors in loops to act this way it would need to be a right click menu to turn the tunnel into a normal one, a shift registered one, or a preserve and merge one.
That is what I want.
Currently, DETT looks like this:
But it should look like a proper profiler allowing for exploring and easily visualizing performance, threads, call stacks and memory usage at a glance (similar to this):
I often run into the issue that I have one event case that I need to execute for multiple controls. Most of the times I simply read out the terminals and most of times I get the "NewVal" from the terminal. Some times however that's not the case. I'm currently having the issue that I use a property node of a control to trigger the event and every other time the terminal gives out the "OldVal".
I believe the proper way to solve this issue would be to go by the reference. I find this blows up the code more than it should do. Looking around in the community I've found two other ideas suggesting different solutions for this issue:
The first has multiple boolean controls triggering the same event. SectorEffector's solution was asking for a reference case structure, which might be a great idea, especially when the event is triggered by different data types. When I have multiple boolean triggering one event I almost always build an array from the terminals and convert the array to an integer, so that a case structure or other code can deal with the value. But again I'd have to deal with fiddling the new value from the triggering control and the other control values together.
The second mentions actually two ideas. The actual idea of rcpacini is to have an enum indicating which control triggered the event. This is a similar approach to what SectorEffector suggested. They're both aiming at using a case structure with a different cases for each event source. The alternative idea of rcpacini was to have event data elements for each control. The is more similar to my idea, but I would like to have the values of all registered event sources clustered together.
Here a side by side of the current solution and what I'd suggest:
New value by referenceNew value by referenceNew value clusterNew value cluster
The order of the events would determine the order of the values in the cluster, so a way to arrange the events like a move up and move down button would be helpful:
Event source order up/down buttonsEvent source order up/down buttons
When debugging a program, I'd love to have a node similar to the "abort vi" node that programmatically pauses execution instead of stops it completely.  You might say this is the place for a conditional breakpoint, but unless I create my own custom ones, it's hard to make something that breaks on, say, the third time an error of this type occurs.
I have places in the code where I throw an error that is fatal(-ish), but it isn't caught until much further downstream.  In order to find which of the many calling vis triggered this error, I have a few options:
1) I can list the call chain.  This works, but still takes until the point the error is caught by my error handler popup to actually list the full problem, and due to either programmer error or bad design, can sometimes be overwritten by other errors thrown and badly merged further down the line.
2)  I can delete the error wires throughout the program and ensure automatic error handling is enabled.  This pops up the problem immediately, but often I don't have enough context to know if the error is the one I'm trying to track down, and my only options are to continue or stop.
3) I can throw multiple conditional error probes or breakpoints throughout the program, which works, but both are ephemeral as most of the time they're cleared using the "delete all breakpoints" button, and probes are lost when you close the window.  I'd like a more permanent and preventative solution.
So I'm going through a bunch of VIs and relinking them.  So I go to a folder and select say 100 VIs and drop them into a new blank VI.  A bunch of dialogs come up telling me VIs are missing and I ignore them all at the moment.  Then I go to the block diagram to find which ones are broken to review them one at a time.  The only problem is the error list window displays over 100 errors that aren't "SubVI is not Executable".  I have all kinds of errors about required inputs not being wired, and for "This VI cannot access the referenced item in private scope".  Well I don't really care I'm not trying to run these I'm just trying to find all broken VIs and fix them.
Which got me thinking, can we have a category view of some kind in the Error List Window?
Under Web Services there is a conversion palette.  One of the functions here is to convert LV Image data to a PNG stream.  This is super useful when dealing with sending and receiving large amounts of PNG data over something like websockets.  I've used this in places where a web page can control a VI, and the image of some front panel controls can be sent to the web page.
However only recently did I realize this function turns the image into a PNG stream that is completely uncompressed.  This idea is to expose the Compression input to the VI.  Here is just one example where I get the image of a control then represent it as a PNG.  With no compression this file is over 64KB.  With just the most minimum compression that drops to 3KB, and down to 2KB under the highest compression.
A Diagram Disable structure lets all the code that isn't inside of it execute but not what is inside of it. I think it would be helpful to put a structure around a snippet of code and execute only what is inside the structure. I usually copy and paste it into a new vi but it would be helpful to have that functionality within the vi i'm working on.
If I create a zip file for my build distribution in a LabVIEW project, I can choose "Zip entire project" for Source Files.  In this case, the lvproj file is included.  However, if I don't check that box and instead pick specific files to include, the lvproj file is not included.
Sometimes, there may be installers and other drivers included in the project that I don't always want to include for size reasons during development.
I'd like to be able to choose whether or not to include the lvproj file when making a zip.
