Community Browser
Post an idea
Please add to AF:
Interface based messaging. The need to create messages for all communication is a major decrease in productivity and speed of actor programming. It also decreases readability. It is a better with the BD Preview in Choose Implementation Dialog in LV19, but still.
Please include into AF:
Certain templates, standard actors, HALs, MALs should be part of the framework e.g. TDMS Logger Actor, DAQmx Actor. Right now the framework feels naked when you start with it, and substantial effort is required to prepare it for real application development. The fact that standard solutions would not be perfect for everyone should not prevent us from providing them, because still 80% of programmers will benefit.
Please add to AF:
Ability to seamlessly communicate over the network and create your own queue specifications. For example actors should be able to talk between physical systems. Using the Network Actor is not a good solution, because it is simply to verbose and difficult to understand. The philosophy of AKKA should be embraced here "
This effort has been undertaken to ensure that all functions are available equally when running within a single process or on a cluster of hundreds of machines. The key for enabling this is to go from remote to local by way of optimization instead of trying to go from local to remote by way of generalization. See this classic paper for a detailed discussion on why the second approach is bound to fail."
Please add to AF:
Ability to Get Actor Enqueuer by Path through hierarchy of actors e.g. /root/pactor/chactor could be used to get the enqueuer to chactor. This would probably require actors to have unique paths pointing to them. Having a system manager keeping all enqueuers on local system is not a bad thing. It is a good thing.
LabVIEW AF is a fantastic tool to create multi-threaded messaging applications the right way. It promotes best practices and help write big yet scalable applications.
I feel however that there is not enough included in the box 🙂 When looking at many other industry implementation of the actor model e.g. Scala Akka, Erlang, Elixir, microservices in many languages etc. you find that the frameworks usually include many more features. https://getakka.net/
I understand the decisions behind the design for AF yet would like to start a discussion about some of these.
I would like to see the following features being included into AF:
1. Ability to Get Actor Enqueuer by Path through hierarchy of actors e.g. /root/pactor/chactor could be used to get the enqueuer to chactor. This would probably require actors to have unique paths pointing to them. Having a system manager keeping all enqueuers on local system is not a bad thing. It is a good thing.
2. Ability to seamlessly communicate over the network and create your own queue specifications. For example actors should be able to talk between physical systems. Using the Network Actor is not a good solution, because it is simply to verbose and difficult to understand. The philosophy of AKKA should be embraced here "This effort has been undertaken to ensure that all functions are available equally when running within a single process or on a cluster of hundreds of machines. The key for enabling this is to go from remote to local by way of optimization instead of trying to go from local to remote by way of generalization. See this classic paper for a detailed discussion on why the second approach is bound to fail."
3. Improved debugging features like MGI Monitored Actor being inbuilt. https://www.mooregoodideas.com/actor-framework/monitored-actor/monitored-actor-2-0/
4. Included Subscriber Publisher communication scheme as a standard way for communicating outside the tree hierarchy. https://forums.ni.com/t5/Actor-Framework-Documents/Event-Source-Actor-Package/ta-p/3538542?profile.language=en&fbclid=IwAR3ajPR1lvFDyPFP_aRqFZzxR4FCQXh2nB2z0LYmPRQlnvXnsC_GQaWuZQk
5. Certain templates, standard actors, HALs, MALs should be part of the framework e.g. TDMS Logger Actor, DAQmx Actor. Right now the framework feels naked when you start with it, and substantial effort is required to prepare it for real application development. The fact that standard solutions would not be perfect for everyone should not prevent us from providing them, because still 80% of programmers will benefit.
6. Interface based messaging. The need to create messages for all communication is a major decrease in productivity and speed of actor programming. It also decreases readability. It is a better with the BD Preview in Choose Implementation Dialog in LV19, but still 🙂
7. This is more of an object orientation thing rather than actor thing but would have huge implications for actor core VI, or Receive Message VI. Please add pattern matching into OO LV. It could look like a case structure adapting to a class hierarchy on case selector and doing the type casting to the specific class inside the case structure. You could have dynamic, class based behavior without creating dynamic dispatch VIs, and you would still keep everything type safe. https://docs.scala-lang.org/tour/pattern-matching.html
The natural way for programming languages to evolve is to take ideas from the community and build them into the language. This needs to also become the LabVIEW way. I saw a demo of features of LV20 and I am really happy to see that many new features were inspired by the community. Lets take some ideas about actor and add them in.
I wanted to share my view on the direction I think AF should go. I see in it the potential to become the standard way to do big applications, but for that we need to minimize the barrier to entry.
Traditionally LabVIEW has treated Strings and Unsigned Byte Arrays as being the same. This is nowadays a little unfortunate as all UI systems use some kind of encoding so Strings are not generally interchangeable with Byte Arrays anymore.
In trying to stay for binary data as much as possible with Byte Arrays instead of Strings, since that would be the sensible thing to do, the Unflatten from String (which should rather be called Unflatten from Stream) puts a totally unnecessary wrench into this.
I always had hoped that LabVIEW would change the default binary data stream format to a Byte Array at some point but this while it would be possible, is a fairly pervasive change that would require many backwards compatibility decisions that I unfortunately don't see NI going to spend time on anymore. This change however would be a very small change that has zero backwards compatibility concerns and almost no work to add to the existing LabVIEW software.
This same change has been for instance made to the TCP Write node some versions back already and could be also applied to the VISA Write! Smiley LOL
It would be nice if the LabVIEW primitives for TCP allowed for the creation of a socket without actually connecting it to an endpoint.  My thoughts are that there would be two new commands added to the TCP palette:
TCP Create Connection (Advanced)
TCP Open Connection (Advanced)
TCP Create Connection (Advanced) would create the socket but not perform the connect() method on that socket.  I would imagine that it would otherwise look and feel quite like the current TCP Open Connection, except that the user would need to manually run TCP Open Connection (Advanced) afterwards that would perform the connect() method on that socket.
I have a need to access the raw socket object before it is connected, using the TCP Get Raw Net Object.vi in the vi.lib\Utility\tcp.llb library.  This VI works to get the handle that can be used by winsock and other Windows DLLs, however, it only allows for setting properties for a socket that is already connected.
Specifically I have a need to enable Windows FastPath for TCP to optimize the rate at which I can stream data between two applications.  Per the specification, this option must be enabled BEFORE the socket is connected.  Right now I can set this for the listener on the server side (TCP Create Listener creates a socket but does not connect), but I cannot set it for the TCP connection on the client side as the first method it calls is TCP Open Connection which returns a socket that is already connected.
The 2017 and 2018 versions of the LabVIEW OPC UA Toolkit support data access amongst other features.
Is there already a plan or schedule to implement the PubSub amendment (nr 14) and provide PubSub support for the OPC UA toolkit?
I'm writing a VI for a lab which writes to a database. The number of measurements will vary depending upon which fixture is set up in the lab, and whether the experimenter decides to add extra ones. This results in a varying size array of doubles which gets written into a single database with generic column names c1-c200. The column names are cross-referenced in another table keyed to the lab fixture.
The method I found here is to convert from array->cluster->variant->database insert. The problem with this is that a cluster's size must be available at compile time, making the varying array size more difficult. It also limits the size of the array/database entry to 256 elements in the array->cluster conversion.
I know I could just populate and write a 200 element array into the database, but that increases database activity , is inelegant, and forces me to put zeros in the unused columns, instead of leaving them null.
Attached is a VI which demonstrates what I would like, though it only works for doubles and is still limited by the 256 element limit. It could very easily be changed for integers or strings, but it would be best if it could take any type of array input, with a much larger size limit.
Dear all,
timeouts and UID properties of "Modbus Master.lvclass" and "Modbus Slave.lvclass" can currently be set but not read out (they should).
See discussion here.
Sincerely,
With the advent of the IoT and the growing need to synchronize automation applications  and other TSN (Time Sensitive Networking) use cases UTC (Coordinated Universal Time) is becoming more and more problematic.  Currently, there are 37 seconds not accounted for in the TimeStamp Which is stored in UTC.  The current I64 portion of the timestamp datatype that holds number of seconds elapsed since 0:00:00 Dec 31, 1900 GMT is simply ignoring Leap Seconds.  This is consistent with most modern programming languages and is not a flaw of LabVIEW per se but isn't quite good enough for where the future is heading   In fact, there is a joint IERS/IEEE working group on TSN
Enter TAI or International Atomic Time: TAI has the advantage of being contiguous and is based on the SI second making it ideal for IA applications.  Unfortunately, a LabVIEW Timestamp cannot be formated in TAI.   Entering a time of 23:59:60 31 Dec 2016, a real second that did ocurr, is not allowed.  Currently IERS Bulletin C is published to Give the current UTC-TAI offset but, required extensive code to implement the lookup and well, the text.text just won't display properly in a %<>T or %^<>T (local abs time container and UTC Abs time container)  We need a %#<>T TAI time container format specifier. (Or soon will!)
The NI SMTP library is good at making e-mailing simple. But now and then I will get error 363513 (an error occurred on the network).
There are multiple known causes for this error that one can prevent, but also some unknown. The error does not specify them. I am therefore still struggling to get my e-mailing routines impervious to this error. The library should return more specific errors.
There are multiple other known issues with this library, making it quite unreliable for automation purposes. A shame, as there are few alternatives available.
A few suggested VIs for beefing up this library could be:
  • check if server is online
  • set popular SMTP header values (I don't know them, like most of us I assume)
  • check if e-mail was successfully sent to recipients
  • meta data returned: unknown recipient, attachment size exceeds limit of xMB etc
When working with serial, tcp or some other odd communication protocol I find myself time and again working on a PC that either has nothing installed, can't install anything or is sitting behind a secured environment. Nor is there always a scope with analyzer readily available to trace the commands being sent & received to an instrument or DUT.
Can't parts of Wireshark or an another sniffer be built right into the Probe Watch functionality? That would be sweet.
P.S. VISA's "Interface Information:Interface Type" has a lot of variations that many devs likely don't even know about as they just drag a VISA onto the BD/FP.
This would be useful for variables whose value is not yet available at deployment time, and is filled later by some process.
Currently (LV2017.1f3), it is not even possible to input a non-numeric value in the inital value page in the variable editor. Attempting to do it programmatically like this:
produces a LabVIEW:  (Hex 0x8BBB0018) Invalid float value.
Whereas, blindly editing the lvlib file to
<Property Name="Initial Value:Value" Type="Str">NaN</Property>
produces a "deployment failed (error: -1950678996, LabVIEW:  The variable configuration is invalid.  Edit the variable properties to correct the configuration.)." at deploy time.
The current version of the Ethernet/IP tool kit 781656-35 only functions as an adapter. I need it to also function as a scanner. Specifically to take control  of the point I/O module 1734-AENT module of the Allen Bradley RSlogix 5000 PLC. I need the Labview to replace the PLC RS l5000 logix software. I still want to use the Point IO modules.
'Database Variant To Data' cannot be placed in an inline enabled VI making it impossible to use in malleable VIs.
It would be nice to be able to draw on the power of the 'Database Variant To Data' VI in malleable VIs so we could be more flexible when writing database related code.
Please make this possible or offer a workaround (like the polymorphic instances of the VI).
Currently, the only way to add a webservice to a project, is by right clicking a Target and selecting New->Web Service.
There's no way to add existing Web Service definitions to a project, other than manually performing the copy operation at the XML file level.
This prevents proper re-use of IP!
I would propose extending the capabilities of a Library to also support Web Service definitions as Child objects.
That way, the library can act as a container for the Web Service definition, and can easily be reused in other projects:
I tried using an XML editor to manually put a Web Service definition underneath a Library, LabVIEW didn't like that!
What is needed :
A direct property to change the "Enable Aliasing" option (var_params.png). "Use binding" property only allows to user to change it after enable + deploy the shared variable with "Enable Aliasing" option manually checked once.
Problem in detail:
When a shared variable is created in a local library file, it is needed to check the "Enable Aliasing" checkbox manually once to connect to an URL of a remote tag / psp URL.
After that, Enable aliasing parameter can be changed from the program via the parameter "Use binding". If an attempt to connect the variable to an URL is made with "Enable Aliasing" is not changed manually once beforehand, "A value is missing for the Enable Aliasing option" (missenable.png) or "Missing access type" errors occur (mat.png).
Why is it needed for :
Lack of this property permits the user to create shared variables with an URL connection in a Labview program . You need to create and check "Enable aliasing" manually once each time you need to create a shared variable.
