Access violation C0000005 NI MAX error
Could anybody help with this error message?
Seems like anything is wrong with NI MAX, in addition, when I do right-click on "Devices and Interfaces" nothing happens...I cannot see the dialog "Create new".
I am with Windows 7 64-bit
Message 1 of 11
(6,400 Views)
Sounds like an old bug... euh... issue...
Have a look here if you have Visual Studio installed.
Message 2 of 11
(6,377 Views)
Thanks Ray,
But it didn't work, I tried to uninstall Visual Studio, uninstall LabView and install again LabView, but still having the same problem.
Message 3 of 11
(6,358 Views)
Did you try re-installing NI MAX?  or was that part of the LabVIEW re-install?
Message 4 of 11
(6,345 Views)
Yes, everything included in the LabView instalation, LabView and MAX
Message 5 of 11
(6,337 Views)
What drivers and versions have you installed with LabVIEW? And does the access violation happen after clicking Tools>>Reset Configuration Data and restarting?
If this is still happening, can you click Send on the crash report window you posted and then Copy/Paste the Report ID here so we can take a look?
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
Message 6 of 11
(6,332 Views)
Hi Zachm,
I have installed the LabView package without any driver, that means, unchecking the option about the drivers when installing, and still having the same problem.
And, for further information, I will tell you that, if I open NI MAX, and do nothing, that means, just open, let it load, and close, then nothing happens, but, when I open and click on the arrow on "Devices and Interfaces", let it load and then I close NI MAX, then it closes and I get the message posten on my first post.
In addition, as I said before, if I try to right-click on "Devices and Interfaces" looking for  "Create new...", nothing happens, I do not get any response.
If you need ony other info in order to be able to help me plesae ask me, no problem.
Thanks!
Message 7 of 11
(6,310 Views)
P.D: I have already clicked on the "Send" button from the error message like 2 or 3 times, so you may have it somewhere there at NI.
And, about the LabView version:
Message 8 of 11
(6,290 Views)
Sorry I forgot the report ID
Report ID : a2a594c7-3954-4462-a29b-a2548e1fdf1d
Thanks for your help.
Message 9 of 11
(6,287 Views)
We pulled up your report in our crash database. It looks like Ray is correct. The crash is occurring in a very old (1998) version of PDM.dll. It looks like this dll shipped with Visual Studio 6 and Office 2000. I would recommend finding a way to update that DLL or you could try removing it (making sure to preserve a back-up) if you are not using Visual Studio 6 or Office 2000.
Message 10 of 11
(6,227 Views)
