How to become a bad labview developer - According to ChatGPT
💀 How to Become Bad at LabVIEW
1. Use Only Flat Sequence Structures
Because nothing says "professional" like a 3-screen-wide sequence with 50 frames and no comments.
  • Completely ignore state machines, events, or QMH.
  • Use "Frame 32" to control logic instead of meaningful state names.
2. Spaghetti Wires Everywhere
Why route wires cleanly when you can just cross them 100 times?
  • Don’t label wires.
  • Cross wires over front panel terminals and structures.
  • Use random colors for signal wires to make it "artistic".
3. Never Use Typedefs
Just create 17 copies of that enum and update them individually.
  • Bonus points for different ordering of the same enum in different VIs.
4. Global Variables for EVERYTHING
Who needs data flow when you can have data chaos?
  • Use global variables to pass data between states, loops, even parallel VIs.
  • Watch your code randomly break when race conditions occur!
5. Write One Giant VI
1000x1000 pixels. One VI. One love.
  • Don’t modularize.
  • Put all logic in one huge block diagram.
  • Nest structures 10 levels deep.
6. No Error Handling
Just wire errors into a constant and move on. YOLO.
  • Errors are suggestions, right?
7. Poll Everything in a Tight Loop
Efficiency? Never heard of it.
  • Check every button and sensor every millisecond, in a greedy polling loop.
  • Who needs event structures or timing?
8. Don't Use Documentation
Comments are for the weak.
  • Use cryptic abbreviations like xxRTCB_Ctrl.vim with no explanation.
  • Bonus: Delete all front panel labels and captions.
9. Ignore LabVIEW Style Guides
Standards stifle creativity!
  • Use different styles in every VI.
  • Mix camelCase, snake_case, and CAPSLOCK.
10. Save Everything on Desktop, No Version Control
If you lose your code, that’s fate.
  • No Git, no SCC, no backups. Overwrite previous versions with "final2.vi", "reallyFinal.vi", "NEWfinal(3).vi".
11. Hardcode Everything
Make sure every path, value, and constant is typed manually. Preferably in multiple places.
  • Forget INI files or config clusters.
  • Want to change the baud rate? Go find it buried in 12 different places.
12. Ignore User Events, Producer-Consumer, or Queued Message Handlers
Use one loop. One big loop. Forever.
🎯 Result:
Your boss cries. Your co-workers quit. LabVIEW crashes. NI sends a representative to ask what you've done. 🤣
(255 Views)
Other possible result: The hacker gets the code limping along; and the boss, never looking under the hood, thinks it's a job well done.
(219 Views)
Sad to say this is what happens most often. Early in my career I was handed some LabVIEW code that was heralded as one of R&D's greatest achievements and told to modify it for the V&V lab. The code was one big loop (OBL) full of locals and flat sequences. To read it you had to follow the Error Cluster squiggling around the block diagram like following a treasure map. (facepalm)
I put my foot down and flat out refused. Then wrote a better more modular program that fit our lab's needs from scratch in less time that I estimated it would have taken to fix that code.
=== Engineer Ambiguously ===
(201 Views)
At least he had an error line, you can give him that 😄
(114 Views)
Spot on! Except the singular VI should be at least 10k x 10k!
Qestit Systems
Certified-LabVIEW-Developer
(74 Views)
