How to become a bad labview developer - According to ChatGPT
💀 How to Become Bad at LabVIEW
1. Use Only Flat Sequence Structures
Because nothing says "professional" like a 3-screen-wide sequence with 50 frames and no comments.
  • Completely ignore state machines, events, or QMH.
  • Use "Frame 32" to control logic instead of meaningful state names.
2. Spaghetti Wires Everywhere
Why route wires cleanly when you can just cross them 100 times?
  • Don’t label wires.
  • Cross wires over front panel terminals and structures.
  • Use random colors for signal wires to make it "artistic".
3. Never Use Typedefs
Just create 17 copies of that enum and update them individually.
  • Bonus points for different ordering of the same enum in different VIs.
4. Global Variables for EVERYTHING
Who needs data flow when you can have data chaos?
  • Use global variables to pass data between states, loops, even parallel VIs.
  • Watch your code randomly break when race conditions occur!
5. Write One Giant VI
1000x1000 pixels. One VI. One love.
  • Don’t modularize.
  • Put all logic in one huge block diagram.
  • Nest structures 10 levels deep.
6. No Error Handling
Just wire errors into a constant and move on. YOLO.
  • Errors are suggestions, right?
7. Poll Everything in a Tight Loop
Efficiency? Never heard of it.
  • Check every button and sensor every millisecond, in a greedy polling loop.
  • Who needs event structures or timing?
8. Don't Use Documentation
Comments are for the weak.
  • Use cryptic abbreviations like xxRTCB_Ctrl.vim with no explanation.
  • Bonus: Delete all front panel labels and captions.
9. Ignore LabVIEW Style Guides
Standards stifle creativity!
  • Use different styles in every VI.
  • Mix camelCase, snake_case, and CAPSLOCK.
10. Save Everything on Desktop, No Version Control
If you lose your code, that’s fate.
  • No Git, no SCC, no backups. Overwrite previous versions with "final2.vi", "reallyFinal.vi", "NEWfinal(3).vi".
11. Hardcode Everything
Make sure every path, value, and constant is typed manually. Preferably in multiple places.
  • Forget INI files or config clusters.
  • Want to change the baud rate? Go find it buried in 12 different places.
12. Ignore User Events, Producer-Consumer, or Queued Message Handlers
Use one loop. One big loop. Forever.
🎯 Result:
Your boss cries. Your co-workers quit. LabVIEW crashes. NI sends a representative to ask what you've done. 🤣
Message 1 of 11
(1,136 Views)
Other possible result: The hacker gets the code limping along; and the boss, never looking under the hood, thinks it's a job well done.
Message 2 of 11
(1,100 Views)
Sad to say this is what happens most often. Early in my career I was handed some LabVIEW code that was heralded as one of R&D's greatest achievements and told to modify it for the V&V lab. The code was one big loop (OBL) full of locals and flat sequences. To read it you had to follow the Error Cluster squiggling around the block diagram like following a treasure map. (facepalm)
I put my foot down and flat out refused. Then wrote a better more modular program that fit our lab's needs from scratch in less time that I estimated it would have taken to fix that code.
=== Engineer Ambiguously ===
Message 3 of 11
(1,082 Views)
At least he had an error line, you can give him that 😄
Message 4 of 11
(995 Views)
Spot on! Except the singular VI should be at least 10k x 10k!
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 11
(955 Views)
ChatGPT is very good in collecting the obvious from the internet, when it doesn't hallucinate eloquently and with absolute authority. 😁
Rolf Kalbermatter  My Blog
Message 6 of 11
(806 Views)
That sounds awful...
That sounds fun however. A whole different meaning to being a pirate behind a computer hehe
Message 7 of 11
(779 Views)
I ignore 2 out of 3 of those 😁.
See the eXtreme Go Horse Methodology (XGH) for general programming practices.
Message 8 of 11
(767 Views)
But if it so obvious, why do you run into those things so often?  😄
Bill
CLD
(Mid-Level minion.)
Message 9 of 11
(710 Views)
Well, it was maybe a bit short: there are people who know enough about a subject to be dangerous but not enough to know they are dangerous. For those this list could be not so obvious but they are also not likely to go and ask ChatGPT about this.😁
But each of these points has been listed multiple times on this forum, LavaG, Info-LabVIEW and others in the last 30 years or so. 😎
Message 10 of 11
(690 Views)
