How to fix negative numbers in u16 images
I have a 2d array that is u16 (0-65K) and trying to subtract a "dark" from it. The problem is that it sometimes yields to negative numbers and it does a wrap around and shows the values as 65K. Is there a truncate function or something to make them zero. Sorry if this is a simple question. I have only been doing labview for a couple of weeks.
Message 1 of 10
(4,637 Views)
Accepted by imageproblems
imageproblems,
Have you considered casting the U16 to I32, making your subtraction, coercing the value such that it does not fall below zero and finally casting it back to U16?
I don't know but this might work for you...
Cheers, Matt
Message Edited by mtat76 on 05-17-2010 11:08 PM
Message 2 of 10
(4,622 Views)
Thank you. That works.
Message 3 of 10
(4,595 Views)
Sorry, I meant to click the solution on your post and clicked it on mine. Wheres the undo button. Thanks again.
Message 4 of 10
(4,590 Views)
THe Options drop-down (top right) has a option to remove the solution marking.
Ben
Message 5 of 10
(4,585 Views)
Sorry. I dont see it. I see an options menu on each reply but that has nothing about clearing it. Looking at the screen, i see a thread option on the left but that has nothing about clearing the solution either.
Message 6 of 10
(4,568 Views)
Haha...Ben's the master!  Thanks, Ben.
Message 7 of 10
(4,558 Views)
The options menu to the upper right of the message that you incorrectly marked.
Message 8 of 10
(4,542 Views)
Got it.
Thanks sorry for the hassle.
Message 9 of 10
(4,531 Views)
Hassy wrote:
This is a fantastic website and information is also outstanding like ccnp magnificent in study affairs. I am very mindful about ccsp. results. I want help or good resources that prepare me and give best guidance for cisco certification. Have you any awareness about it?
__________________________________________________________________________
crm certification ll db2 certification dumps ll ence ll itil braindump
Message 10 of 10
(4,462 Views)
