How to illiminate some local variables
That didn't work.
Message 11 of 43
(1,956 Views)
They are in there.
Message 12 of 43
(1,958 Views)
@RHutchings wrote:
That didn't work.
Because you didn't do what I coded.  Turn off indexing on the array input.  And remove the Build Array function on the outside of the loop.
aputman
Message 13 of 43
(1,950 Views)
@RHutchings wrote:
Thanks. That's what I did. Here's where I'm at after making some sub vi's.
As I said, all lower code should be in its own event case, with a 1D array running through all cases, getting data added or removed depending on the event.
Message 14 of 43
(1,942 Views)
"Because you didn't do what I coded.  Turn off indexing on the array input.  And remove the Build Array function on the outside of the loop.  "
Done and it works great! Thank you.
Message 15 of 43
(1,932 Views)
@RHutchings wrote:
They are in there.
The image didn't show it.
Message 16 of 43
(1,926 Views)
"If you must use the RGT to retrieve values from an XLS file, set the datatype on the Excel Get Data to be an array of doubles.  No post-import conversion would be required on your part."
How?
Message 17 of 43
(1,915 Views)
Message 18 of 43
(1,910 Views)
gregoryj,
Your mouse is over the dbl value but the OP needs the [dbl] selection (array of doubles).
aputman
Message 19 of 43
(1,907 Views)
Oops, I don't use that function and I figured it was like reading a delimited spreadsheet where all the data is in arrays. Good catch!
Message 20 of 43
(1,904 Views)
