How to illiminate some local variables
I don't think I want to change it to doubles because I will be using the headers as well.
My next hurdle will be manipulating the measurement data. What I have here is before and after measurements on 1 to 4 supply currents. I measure all supplies and then check for changes of 10mA or more according to the latch-up spec.
if I have only 2 supplies, to make it simple, here's what I need to do.
number  supply #    measurement
    1          1              2mA
    2          2              1mA
    3          1               2mA
    4          2               11mA  Failure
find difference by subtracting
number 1 from number 3 (Supply1)
number 2 from number 4 (Supply2)
Message 21 of 43
(1,725 Views)
Message 22 of 43
(1,715 Views)
Will that scale?
How about
mcduff
Message 23 of 43
(1,705 Views)
@DickHutchings wrote:
I think I found a good way to do it.
A couple of crossed wires is better than a pile of blue wired indices.
Message 24 of 43
(1,704 Views)
McDuff, I have no idea how you came up with this arrangement, I'll study it some more. Will it scale? That could be a problem.  It needs to do the math on 1, 2, 3 or 4 supplies.
Message 25 of 43
(1,696 Views)
What is "it"? Please always quote relevant sections when replying. There are many posts above.
How many elements per supply? Two or four? (e.g. If there is only one supply, what's the value of the second element?)
If each supply adds four elements to the array, you could do something like that...
Please show us typical arrays for 1, 2, 3, and 4 supplies so we can understand the problem.
Message 26 of 43
(1,688 Views)
@mcduff wrote:
Will that scale?
Your shift registers serve no obvious purpose. regular, non-indexing input tunnels would be sufficient.
Message 27 of 43
(1,680 Views)
There are 2 elements per supply and there could be 1,2,3 or 4 supplies. Because I take the measurements on all supplies sequentially and then repeat the measurement once for all the supplies, it's a bit of a tangled mess to work with.
Message 28 of 43
(1,677 Views)
@altenbach wrote:
@mcduff wrote:
Will that scale?
True. But maybe the OP wants to interleaves the arrays at the end to recover the original array, or do something else with the decimated arrays, I have no idea, just leaving options available. But if the array is not needed then you are completely correct, no shift registers needed.
mcduff
Message 29 of 43
(1,676 Views)
There are billions of possible messes. Can you a bit more specific?
Since the array elements for one supply are not adjacent, would you get one array with three elements if there is only one supply, discarding the second element? I asked for example arrays for 1,2,3, 4 supplies. Please give examples.
Message 30 of 43
(1,670 Views)
