LabVIEW community edition won't activate
After trying everything from the other similar thread, nothing has worked.
I installed a trial version of labVIEW professional before I found out about the CE edition, so at one point I had both. I thought the pro edition was interfering, so I uninstalled everything and reinstalled CE again (everything from the same, brand new, account). I'm on Windows 10.
This is what I see:
I can right-click LVCE and click activate, and that menu just says there was no activation code with my account:
I tried doing an activation code submission form, but I don't have a serial number because I have no network license. I think I still have conflicting versions, or something, on my system, but that doesn't explain why I can't get this one program to activate, and I've spent a lot of time going back and forth and being confused. What can I try next?
And My Products shows nothing:
Message 1 of 55
(9,050 Views)
I found that it's a pain sometimes to activate LabVIEW Community Edition (CE).  You might have to ask NI for help with that.
Bill
CLD
(Mid-Level minion.)
Message 2 of 55
(9,011 Views)
Yes, I just tried activating 2020 SP1 CE and it failed in the same way.  I have a feeling this new "easy" way of activating CE based on account is going to be a lot harder than it should be...
Bill
CLD
(Mid-Level minion.)
Message 3 of 55
(8,998 Views)
Accepted by RookiePresent
I ran in exactly the same issue.
Following is what worked for me (after download and install of LabView 2020 SP1):
- started the download of LabView CE 2020 (not SP1!)
(noticed adblock blocked something)
- allowed add's in adblock
Hereafter I noticed that LabView CE was added to the 'My Product' page.
Now it was possible to activate via NI license manager.
Hope this helps.
Message 4 of 55
(8,985 Views)
Hope this helps.
Unfortunately, it's already added to my account because I had LV 2020 CE installed already.  So actually I have a valid license; I just can't apply it!  Ugh.
If I remember correctly, CE used to have a serial number, now it does not.  Maybe the licensing is caught in a hybrid situation where part of the licensing is still expecting a serial number.
Bill
CLD
(Mid-Level minion.)
Message 5 of 55
(8,978 Views)
I tried to contact customer support, but it doesn't even let you submit the form unless you provide a serial number, which CE doesn't have. I tried a couple of other options to contact them directly and ask for help, but they don't make it easy, and I ran into similar road blocks each time.
Message 6 of 55
(8,959 Views)
Success! It was as simple as uninstalling, and reinstalling with adblock disabled for the NI website. Thank you so much, that was a lot of effort for a free program.
Message 7 of 55
(8,948 Views)
I'm actually surprised that someone from NI hasn't wandered by and answered here by now.
Bill
CLD
(Mid-Level minion.)
Message 8 of 55
(8,945 Views)
Great that it worked out!
Message 9 of 55
(8,939 Views)
Frankly, I'm getting very disgusted with NI.  They've gone downhill since the new management.
Bill
CLD
(Mid-Level minion.)
Message 10 of 55
(8,885 Views)
