Lowercase to Uppercase and Uppercase to Lowercase
@paul_cardinale wrote:
Gee, I had no idea that the To Upper Case & To Lower Case functions worked on byte arrays.
Note that you can pull some of that stuff out of the loop (might make it faster):
I doubt it would make a huge difference but I think this will actually result in going over the data twice. Once for the To Upper/To Lower and then again for the For loop. Christian code would only have to touch the data once.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 38
(3,231 Views)
Nowhere in the problem statement did it say it had to properly handle non-alphabetic characters 🙂
Message 12 of 38
(3,223 Views)
Paul, you never know what the compiler might do with all that, but your mod would in principle need to create allocations of several potentially very large arrays (2 exta U8, 2 Boolean!). Mine doesn't. 🙂
Message 13 of 38
(3,221 Views)
Because the problem description was vague I included the possibly(?) implied requirements. 😄
(Quote from above: "assuming all non-alphabetical characters should remain as is")
Message 14 of 38
(3,200 Views)
Oh it's certainly an "obvious" requirement, but my code doesn't work with that requirement so I opted for simplicity and "technical" correctness 😉
Message 15 of 38
(3,198 Views)
Several example solutions have been provided.
There is a function in the Comparison palette called "Lexical Class" that is often overlooked.
Here is an example that uses the Lexical Class function.
Welcome to the world of LabVIEW!
Message 16 of 38
(3,179 Views)
How's this?
Message 17 of 38
(3,169 Views)
How's this?
You are still allocation at least twice as much memory (probably more).
Also note that the entire left side could be replaced by a lexical class classification (4 or 5), which works on U8 (Of course the "class" is I16 (like your boolean to 0,1), so we are losing again 😉 I would still stick with a FOR loop for very large inputs. ;))
Message 18 of 38
(3,141 Views)
@altenbach wrote:
Any reason not to simplify further?
Message 19 of 38
(3,132 Views)
How's this?
OK.  But I'm usually more concerned with speed that with size;
and this:
is about 30 times faster than this:
Message 20 of 38
(3,108 Views)
